kingbobdole Posted December 4, 2006 Share Posted December 4, 2006 Ok, so I'm dropping an EJ25 into my Rx and swapping in favor of the legacy tranny. I know I need the tranny the starter and the rear end, but have a few questions. Answer what you can:banana: 1. Can I swap my LSD chunk into the Leg rear diff with a touch of work? 2. What rear ratios are available in the legs? I saw a 4.11 today and was surprised. 3. Driveshaft? What do I do? I assume that I can use my stock one. 4. Are the imps the only ones that had 23 splines in some cases? Any leg stuff will work right? 4. Anything else to note? Thanks! Link to comment Share on other sites More sharing options...
970subaru Posted December 5, 2006 Share Posted December 5, 2006 4.11 is the most common one you will find in NA 90-94 legacies. I made a thread about combining a clutch type LSD and a 4.11 legacy diff and noone really knew, something about the stub axles not matching and the diff carrier having different amounts of ring gear bolts. only fwd imprezas had 23sp. hope that helps, Link to comment Share on other sites More sharing options...
kingbobdole Posted December 5, 2006 Author Share Posted December 5, 2006 4.11 is the most common one you will find in NA 90-94 legacies.I made a thread about combining a clutch type LSD and a 4.11 legacy diff and noone really knew, something about the stub axles not matching and the diff carrier having different amounts of ring gear bolts. only fwd imprezas had 23sp. hope that helps, Master Huck says that only the legacy diffs work.... donno why, still getting info... Link to comment Share on other sites More sharing options...
