Mendodave Posted December 9, 2006 Share Posted December 9, 2006 right rear? if im looking at the engine , not in the drivers seat rite? cuz if im looking at the engine, where i got ths revv was in the right back behind the carb right rear, looking at the engine, correct. Left and right concerning the engine is when looking at it. that little T is either blue or red or some color, i can't remember d Quote Link to comment Share on other sites More sharing options...
subieman Posted December 9, 2006 Share Posted December 9, 2006 Chill out Dalton. Everything will be ok! Quote Link to comment Share on other sites More sharing options...
crazy D Posted December 9, 2006 Author Share Posted December 9, 2006 hmmmmm ok Quote Link to comment Share on other sites More sharing options...
crazy D Posted December 9, 2006 Author Share Posted December 9, 2006 ahhhhhhhh!!!!!!!!!!!! so many hoses....i need a weber:banana: Quote Link to comment Share on other sites More sharing options...
Mendodave Posted December 9, 2006 Share Posted December 9, 2006 ahhhhhhhh!!!!!!!!!!!! so many hoses....i need a weber:banana: Yeah, and that IS cleaned up a bit. there were more before! d Quote Link to comment Share on other sites More sharing options...
crazy D Posted December 9, 2006 Author Share Posted December 9, 2006 well i appreciate all the help i am not doing anymore tonite....but all the hints u guys have givin me are great....but they all sound like they are just on the surface....the problem lies where i cant see, down underneath everything, cuz i can see fine on the top.....but not on the bottom,,,and thats where i will be heading tomorrow. Quote Link to comment Share on other sites More sharing options...
1bignose Posted December 9, 2006 Share Posted December 9, 2006 well i appreciate all the help i am not doing anymore tonite....but all the hints u guys have givin me are great....but they all sound like they are just on the surface....the problem lies where i cant see, down underneath everything, cuz i can see fine on the top.....but not on the bottom,,,and thats where i will be heading tomorrow. i had the same problem with 84 wagon it ended up being the distributer there a magnet in the distributer that got cracked and it took me a week to figger that out the fuel pump wasint pumping and a few other thing working right but had a distributer sitting around and put it in then it was fine Quote Link to comment Share on other sites More sharing options...
crazy D Posted December 9, 2006 Author Share Posted December 9, 2006 well i found the leak!!!!!!!!!! i havent fixed it yet cuz everything is hot hot hot. its this little round metal thing back behind the carb that looks like it connects rite up to the intake manafold.....does anybody know what the hell this thing is? and how do i go about sealing up tthe leak thanks -D Quote Link to comment Share on other sites More sharing options...
crazy D Posted December 9, 2006 Author Share Posted December 9, 2006 ok i just took some pics and this is what i got.... top 3 photos is what i removed and whats empty on the manifold Quote Link to comment Share on other sites More sharing options...
subieman Posted December 9, 2006 Share Posted December 9, 2006 Thats the EGR Valve Quote Link to comment Share on other sites More sharing options...
hatchsub Posted December 9, 2006 Share Posted December 9, 2006 yup EGR. Is the valve itself leaking or is it the gasket? Quote Link to comment Share on other sites More sharing options...
crazy D Posted December 9, 2006 Author Share Posted December 9, 2006 i think it might be the gasket....i cleaned everything up and put it back on and just got a better piece of hose and now im gonna go put it on Quote Link to comment Share on other sites More sharing options...
crazy D Posted December 9, 2006 Author Share Posted December 9, 2006 alrite well this is what i think it is...........i saw that the leak was still there and when i sprayed it at the base of the carb....near the gasket between the carb and the intake. there it was....so i was tightening it up the bolt nut wasnt tightening down...it was extracting the bolt that bolts it to the intake..... should i just take off the carb.? Quote Link to comment Share on other sites More sharing options...
hatchsub Posted December 9, 2006 Share Posted December 9, 2006 wait your saying one of the carb studs that is sticking out of the manifold is getting pulled out when you tighten it down? If thats true i think your stuck yanking the carb and fixing that stud and resealing the carb down again. Never heard of that one before. Quote Link to comment Share on other sites More sharing options...
crazy D Posted December 9, 2006 Author Share Posted December 9, 2006 yup...the bolt that holds down the carb that comes out of the top of the intake manifold is coming out when i tightened it down....i think im screwed rite there....do i need a new intake manifold now? :mad: Quote Link to comment Share on other sites More sharing options...
hatchsub Posted December 9, 2006 Share Posted December 9, 2006 Im not sure cause im not looking at the carb but what i would try doing if i were you would be to tap that hole out for a slightly bigger stud..and i do mean only slightly bigger. You many also need to drill the hole out on the carb too to fit it over your bigger stud. The only thing im unsure of is how much room you have for a bigger bolt. I remember it being tight back there. And worst comes to worst get another intake and bolt on a weber. Quote Link to comment Share on other sites More sharing options...
crazy D Posted December 9, 2006 Author Share Posted December 9, 2006 thats what i wanted to do but i didnt want it to happen like this...webers are expensive....and i dont think i want to put all this stuff on an engine w/ 230k on it.....god dammit im really pissed :mad: :mad: Quote Link to comment Share on other sites More sharing options...
hatchsub Posted December 9, 2006 Share Posted December 9, 2006 well how was the carb running before the vacuum leak? If it was running fine then just keep it and either tap the hole on the intake for a bigger stud or get another intake for a hitachi 2 barrel and bolt it all together with subaru gaskets. Another hitachi intake can be scored on this board for as little as 20 bucks so dont fret. I got mine for 20 about a year ago on here. Quote Link to comment Share on other sites More sharing options...
NV Zeno Posted December 9, 2006 Share Posted December 9, 2006 Dalton, you might be able to get around that by replacing the stud/nut contraption with a simple bolt of the same size and thread. Remember, if you take the carb off completely, you'll likely have to replace the gasket. I know you're far from town, and the parts stores probably won't have that gasket in stock ("We'll get it in next week"...). BTW, nice job finding where the leak is located! Quote Link to comment Share on other sites More sharing options...
crazy D Posted December 10, 2006 Author Share Posted December 10, 2006 oh good idea dave....i think i have to replace the gaskets anyways...are they spendy? Quote Link to comment Share on other sites More sharing options...
hatchsub Posted December 10, 2006 Share Posted December 10, 2006 cheap as hell...like a few dollars cheap Quote Link to comment Share on other sites More sharing options...
buzzcon Posted December 10, 2006 Share Posted December 10, 2006 Some hardware stores and autopart stores carry healacoil kits. It comes with a drll bit, a healacoil, which looks like threads, and a tap. The healacoil will replace the threads that you had, bring it back to standard size and be stronger. It comes with directions. Make sure you have enough meat around the hole, so that you can drill it a little bigger. If you decide to drill it out and tap it, you might as well put a healacoil in anyhow, to make it that much stronger. Good luck that's my 2 cents and it's worth at least a penny Quote Link to comment Share on other sites More sharing options...
crazy D Posted December 10, 2006 Author Share Posted December 10, 2006 well then i will just get a new gasket set and i couple of bolts and ill do this thing my way:banana: Quote Link to comment Share on other sites More sharing options...
NV Zeno Posted December 11, 2006 Share Posted December 11, 2006 well then i will just get a new gasket set and i couple of bolts and ill do this thing my way:banana: You might want to see if the "substitute bolt" method works before removing the carb..it might save a ton of work for ya. Quote Link to comment Share on other sites More sharing options...
