bkcraun Posted December 9, 2006 Share Posted December 9, 2006 A few days ago, I went to start my 1995 Legacy and all I got was a click. I jumped the car and drove to Advance Auto to have them check evrything (it was a fairly new battery). Everything checked out as good...battery, alternator and starter. I went ahead and bought a new battery anyway for piece of mind. Well this morning, the same thing. Turn the ignition and all I get is a "click". After numerous attempts with jumper cables attached, it finally did turn over and start and has been starting good as new all day. Ignition switch maybe??? I don't have any other ideas. How hard are they to install? Link to comment Share on other sites More sharing options...
sea#3 Posted December 9, 2006 Share Posted December 9, 2006 A few days ago, I went to start my 1995 Legacy and all I got was a click.I jumped the car and drove to Advance Auto to have them check evrything (it was a fairly new battery). Everything checked out as good...battery, alternator and starter. I went ahead and bought a new battery anyway for piece of mind. Well this morning, the same thing. Turn the ignition and all I get is a "click". After numerous attempts with jumper cables attached, it finally did turn over and start and has been starting good as new all day. Ignition switch maybe??? I don't have any other ideas. How hard are they to install? Starter solenoid contacts are worn out You can replace the contacts or replace the starter SEA#3 Link to comment Share on other sites More sharing options...
northguy Posted December 9, 2006 Share Posted December 9, 2006 Check the connection on your battery posts for corrosion. Link to comment Share on other sites More sharing options...
porcupine73 Posted December 9, 2006 Share Posted December 9, 2006 As mentioned it could worn starter contacts. Next time it happens, try tapping the starter with a hammer. If the tapping works it may indicate worn contacts. Or sometimes when the starter sees the hammer it will be scared back into operation. Link to comment Share on other sites More sharing options...
Manarius Posted December 10, 2006 Share Posted December 10, 2006 As mentioned it could worn starter contacts. Next time it happens, try tapping the starter with a hammer. If the tapping works it may indicate worn contacts. Or sometimes when the starter sees the hammer it will be scared back into operation. I second the starter test here. It's a good test. If the hammer fixes it, you know it's the starter. If that doesn't fix it, it may possibly the parking sensor (the sensor that tells the computer that the car is in park to allow it to start). Link to comment Share on other sites More sharing options...
SuBrat84 Posted December 10, 2006 Share Posted December 10, 2006 I would highly recomend checking your battery leads for corrosion.. making sure that the contacts are clean and fit tightly. Check that the positive cable to the starter is tightened down good. Check that the grounds are clean and tight. Do the tapping the starter test as well.. because you gotta love how "tapping with a hammer" fixes so many things!! Link to comment Share on other sites More sharing options...
JPX Posted December 10, 2006 Share Posted December 10, 2006 Starter solenoid contacts are worn outYou can replace the contacts or replace the starter SEA#3 Save your money - go for the contacts first! Since you can occassionaly get this thing running, make your next trip to the alternator repair shop. They usually rebuild alternators and starters......and they will most likely have the contacts you need. They will look like this when you open up the solenoid: Worn contacts at 89,000 miles ................and the $7 replacement contacts: So even after the replacement, 51,000 miles later on the contacts, this is what they looked when the car hit 140,000 miles. Link to comment Share on other sites More sharing options...
bkcraun Posted December 10, 2006 Author Share Posted December 10, 2006 I installed a remanufactured starter from Advance Auto this afternoon.. Very simple to do with the starter on top like it is. Thanks for everyone's help. Link to comment Share on other sites More sharing options...
porcupine73 Posted December 15, 2006 Share Posted December 15, 2006 Just received a set of contacts for a '96 from Courtesy Subaru (http://www.subaru-parts-dealer.com). There was no part # on the baggie they came in. Just posting this pic for reference. Link to comment Share on other sites More sharing options...
johnceggleston Posted December 15, 2006 Share Posted December 15, 2006 Just received a set of contacts for a '96 from Courtesy Subaru (www.subaru-parts-dealer.com). There was no part # on the baggie they came in. Just posting this pic for reference. what did you pay for them? was it hard to install? Link to comment Share on other sites More sharing options...
porcupine73 Posted December 15, 2006 Share Posted December 15, 2006 Hi, good question..checked the invoice, start contact set 45296530, list $8.69, Internet price $5.31 Link to comment Share on other sites More sharing options...
