efi gurus please read, mpfi wiring
  • 2 weeks later...
mpfi into carb car
so, the ONLY part of the harness i have is on page 2. i have power to the injectors and everything on that circuit, the ignition pulse wire off the negative of the coil is hooked up, all the grounds are hooked up. but i still have no led on the computer, and no injector signal. i am missing a power somwhere.
i am wondering if i need the ig pwr supply on the computer powered, along with the starter signal. do i have to hook that stuff up?
right now its all hotwired without any relays. is the fuel injection that picky about everything bing hooked up?
also on the red connector i have a few of the wires putting out .1 volt, are those for guages or sensors?
ug, im looking at a half inch thick piece of aluminum, a brigeport, and a weber, thinking it would be easier to make the weber fit instead of making the efi work. but i hate carbs! somebody please help! anything to get me thinking again
