keltik Posted December 11, 2006 Share Posted December 11, 2006 I saved the seats, all the doors that arent bent and interior trim pieces. I have the one headlight that survived and the gauge cluster and center console/armrest. Now comes the fun part of pulling the engine and gearbox. I got the front of the motor apart and found the timing belt was still intact, however the cam sprockets on the one side had shattered. And i finally know the joy of undoing the crank pulley. After trying a 6ft bar on my ratchet with the car in gear (the engine turned) i got it off using the redneck impact gun - giving the wrench hell with a BFH. http://www.ultimatesubaru.org/photos/showphoto.php?photo=13683&cat=500&ppuser=17976 How can i tell if this motor is worth saving? And how the hell am i supposed to get this air con pump off!?!? Link to comment Share on other sites More sharing options...
ericem Posted December 11, 2006 Share Posted December 11, 2006 Oh noo!!! if that broke, then? is that engine interference? Hopefully there is no internal damage, i wonder if doing a compression check on the pistons would determine whether the engine is worth your time, and/or the valves are bent. Wait do i see the crankcase cracked? or no lol, i dont know what im looking at. Link to comment Share on other sites More sharing options...
brus brother Posted December 11, 2006 Share Posted December 11, 2006 Pine scented air freshener, or was that damaged in the mild altercation? Having seen the original pictures, I still think you could have buffed out the damage. Seriously, good luck going forward (not end over end). Link to comment Share on other sites More sharing options...
ShawnW Posted December 12, 2006 Share Posted December 12, 2006 Id pull the whole engine and leave the compressor on. Disconnect the lines if the refrigerant has leaked out already instead of unbolting it from the engine in the car. You could drop the crossmembers and all the underbody stuff enough to just lift the body off the engine and transmission...junk the body and start looking for a donor body to reinstall it to. You have definately bent the valves in the engine...Id guess 8-10 of them. A leak down test once the engine is out of the car would be best to determine engine condition. Link to comment Share on other sites More sharing options...
keltik Posted December 12, 2006 Author Share Posted December 12, 2006 Thank you shawn for an on topic reply. The refrigerant is still all in it so i just bent all the lines out the way and wrestled the compressor off. Good idea with lifting the body off the engine, may have to try that as everything is so bent up i dont think its gonna come out the other way. Finally how hard should the cams be to turn? On every other engine ive worked on it takes a fair bit of force to rotate them, but on this one they will spin 90-100degrees freely. Anyhows the engines toast, but ill save it all in case i can use some of the parts in my next car. Link to comment Share on other sites More sharing options...
fnlyfnd Posted December 12, 2006 Share Posted December 12, 2006 definately keep the engine/tranny/rear end. Never know if/when you're going to need that stuff. Maybe find a reg. ej20 (if there is one) and swap the ecu and turbo stuff, along with the tranny (prolly different ratios) and the rear end. Link to comment Share on other sites More sharing options...
idosubaru Posted December 12, 2006 Share Posted December 12, 2006 the engine is probably fine. maybe new headgaskets to inspect and replace any valves and you're done. did leak and run out of oil or anything? did you shut it off quickly after the accident, if so it's fine and plenty fixable. like shawn said, replace the bad valves, slap on new headgaskets and on your way. Link to comment Share on other sites More sharing options...
keltik Posted December 12, 2006 Author Share Posted December 12, 2006 The motor was off when the car finally stopped and first instincts made me rip the key out. Oil is still clean and on the full mark, and amazingly the sump is straight and clean. No external problems as far as i can see, well except for the cams on the one head. Ill go down to the rebuilders once ive got the engine out and get them to quote me some parts. Link to comment Share on other sites More sharing options...
WoodsWagon Posted December 12, 2006 Share Posted December 12, 2006 Rotate all the camshalfts so that they turn freely, no spring tension on them, and spin the crank with the breaker bar. If you hear air wooshing past any of the valves, it's teardown time. Link to comment Share on other sites More sharing options...
dj3stripes Posted December 12, 2006 Share Posted December 12, 2006 cupholder and , oldly enough, center dash trim (part that goes around the stereo/climate controls) are items i'd be willing to buy from you Link to comment Share on other sites More sharing options...
waimaks Posted December 12, 2006 Share Posted December 12, 2006 That has been removed, and is ok i think. I can guaruntee it. It is some kind of fake wood colour I think. That is all. Link to comment Share on other sites More sharing options...
johnceggleston Posted December 12, 2006 Share Posted December 12, 2006 Thank you shawn for an on topic reply. The refrigerant is still all in it so i just bent all the lines out the way and wrestled the compressor off. Good idea with lifting the body off the engine, may have to try that as everything is so bent up i dont think its gonna come out the other way. Finally how hard should the cams be to turn? On every other engine ive worked on it takes a fair bit of force to rotate them, but on this one they will spin 90-100degrees freely. Anyhows the engines toast, but ill save it all in case i can use some of the parts in my next car. if you are trashing the rest of the car, get a sawzall and cut away the front bumper, and cross member , and top radiator support (all the cross pieces between the bumper mounting points) and just slide the whole eng / trans. forward. you only have to jack up the car enough to clear the the engine cross member. Link to comment Share on other sites More sharing options...
keltik Posted December 12, 2006 Author Share Posted December 12, 2006 Cheers, the whole front end has been chopped already, dont have a sawzall tho so did it with love and care using a big hammer and a hacksaw. Engine should be coming out today, the intake valves are all opening and closing nicely - i dont know if theyre sealing however, ill check that today. This mornings goal is to get the gearbox seperated, that lower bolt on the starter motor is confusing me and with most of the car disassembled i only snapped one other bolt! Anyone who has requested interior parts or whatever, flick me a pm with your address and ill find out the postage. For the guy who requested the tail lights: thats todays job, so dont panic it shall be done! Link to comment Share on other sites More sharing options...
fnlyfnd Posted December 12, 2006 Share Posted December 12, 2006 thanks bud Link to comment Share on other sites More sharing options...
970subaru Posted December 12, 2006 Share Posted December 12, 2006 the head which had cam sprocket damage may or may not be fubar. a compression test would check this. also if you plan to use them I would magnaflux. in any case, the heads are still worth a little money unless cracked, and the bottom end a couple hundred as its good im sure. Link to comment Share on other sites More sharing options...
keltik Posted December 13, 2006 Author Share Posted December 13, 2006 cupholder and , oldly enough, center dash trim (part that goes around the stereo/climate controls) are items i'd be willing to buy from you Tried to PM you. Need to clear some space in your inbox. Link to comment Share on other sites More sharing options...
gordo Posted December 13, 2006 Share Posted December 13, 2006 Take the cig lighter and put it in the junk drawer beside the knives and forks, it will probaly stay there for years bringing back memories of a beautiful car. Link to comment Share on other sites More sharing options...
