scrapdaddytatum Posted November 16, 2003 Share Posted November 16, 2003 so as some of you know im building a turbo ea82, bar no expense this is going to be sick motor, thought about a twin turbo but the space is not there, so i thing im going for a single front mount garret t-3, mounting the turbo to the side in front of radiator and putting the intercooler right of the turbo beside it, the intake for the turbo wound be a K&N right on the turbo, im using the rare spider intake flipped around so the throttle is facing foward, im having the bottom end completely done out with harding and shotpeening, full balance and blueprinting, JE pistons, true seal rings(file fit) and 8.5 to 1 compression, copper head gasket, shaved gen 3 heads with port and polish, 5 angle valve job, and stainless valves, stock cams, ported and polished intake, arp engine bolt kit(complete), a garret t-3 from turbonetics with ball bearing and ceramic to super 70 a\r trim, this turbo is for a dodge charger, my other addiction, i will be using ej25 injectors and SDS ENGINE MANEGMENT, all this with an rx transmision, act clutch, skip lightened flywheel, lsd rear, byb 3" lift in a 89 gl10 wagon, im aiming for 225hp any suggestions or idea' s also any manufactor for rods or cranks in proformance trim or any other ea82 proformance parts, thanks scrapdaddy Link to comment Share on other sites More sharing options...
WJM Posted November 16, 2003 Share Posted November 16, 2003 Delta Cams. Torque grind. Thats 20 more HP and tons more TQ. Link to comment Share on other sites More sharing options...
Hondasucks Posted November 16, 2003 Share Posted November 16, 2003 :slobber: :slobber: :slobber: :slobber: So where are you getting all your parts? Care to share prices? I'm thinking about building the %*%*@* out of my EA82 as well :-) Link to comment Share on other sites More sharing options...
XSNRG Posted November 16, 2003 Share Posted November 16, 2003 I like what I hear:brow: Link to comment Share on other sites More sharing options...
WJM Posted November 16, 2003 Share Posted November 16, 2003 I got mine form NAPA, Delta Cams, and Gasket Works USA. Oh, the engine from a local subaru mechanic. Link to comment Share on other sites More sharing options...
archemitis Posted November 16, 2003 Share Posted November 16, 2003 did you just write every mod you have ever read about? why would you have shaved heads if you are runing 8.5:1? got any pics? Link to comment Share on other sites More sharing options...
scrapdaddytatum Posted November 16, 2003 Author Share Posted November 16, 2003 thabjs about the cams, didnt know abbout them. im getting most of my machine work done by a local machine shop, like the shot peening and magna fluxing, and another shop for my balancing and blueprinting. im just using basic motor building technics. no pictures yet as most of the has yet to be done. im starting this as a winter builld up. Link to comment Share on other sites More sharing options...
Skip Posted November 16, 2003 Share Posted November 16, 2003 J, the rotation of the spider is going to cause an interesting upper rad hose config (will be pointing at the distributor) The manifold is a two part affair, you may beable to leave the bottom and just rotate the top. Since you have choosen to put the turbo up front if you move the battery to the rear smugglers trunk (Trogdor copywrite) you may have room for twins. Getting another Turbonetics may be a problem, I believe you have some lesser units you could use. Twins are one of those hair brained ideas that just look sophat. One bank of two cyl per turbo may prove retarded though. Time to look into a wideband 02 setup, group buy on the new gen board right now will save a couple bucks. Heat is an enemy you will be fighting with this proj. Big scoop and hood vents?? I'm sure you know of a good rad to use. The IC is going to share this area, may want to think about the WRC "V" setup Other adds - underdrive lightweight harmonic dampner, H20 injection, high boost aux. injectors, NOx, scatter shield (diaper) Bythesea short shifter setup, reinforced motor/tranny/dogbone mounts Good luck - if anybody can jank this off - it B U Link to comment Share on other sites More sharing options...
scrapdaddytatum Posted November 16, 2003 Author Share Posted November 16, 2003 good ideas as usual, dont think i will do the twins though, 1 t-3 will pull enough boost. and i was thinking about the rally v setup i will leave the bottom half the intake normal, just spin the top half, havnt tried it yet but looks like it will fit ill check out that o2 deal Link to comment Share on other sites More sharing options...
beauregaardhooligan Posted November 16, 2003 Share Posted November 16, 2003 That'll be some mondo hp! What trany are you using? Link to comment Share on other sites More sharing options...
scrapdaddytatum Posted November 16, 2003 Author Share Posted November 16, 2003 rx trans, dual range with locking center dif, lsd rear, and if i can fiigure out how, 4.10 gears. also 3" BYB lift, toyota 14" rims, bilstien shocks, poly bushings if i can find them, custum shifter setup, and a rollcage, Link to comment Share on other sites More sharing options...
AlpineRaven Posted November 16, 2003 Share Posted November 16, 2003 Quote "JE pistons" What JE Pistons? what are they? Can you tell me what they are/where they from? Reason - It triggered me, thinking of Holden JE Camira (From Australia) Piston from a 2.0 litre engine. Cheers Tristan Link to comment Share on other sites More sharing options...
WJM Posted November 16, 2003 Share Posted November 16, 2003 check out subspeed.com. He also got some JE pistons. The company is in CA. They are supposed to be just about the best. Link to comment Share on other sites More sharing options...
scrapdaddytatum Posted November 17, 2003 Author Share Posted November 17, 2003 je pistons are huge, run an internet search, i have been using them for years, and i checked out subspeed ill be shooting him an email, thanks agian Link to comment Share on other sites More sharing options...
scrapdaddytatum Posted November 17, 2003 Author Share Posted November 17, 2003 as i get them and put things together dont expect much till after january as im going to the south for a month after christmas so illl be saving money up for my return it will work perfect, this way Link to comment Share on other sites More sharing options...
