Tibia Posted December 14, 2006 Share Posted December 14, 2006 ok so here is my situation i have an 87 gl spfi wagon 5spd d/r 4x4 so far i have replaced timing belts, oil pump seals, cam seals, fuel pump & filter, radiator hoses, thermostat and fans. when i put everything back together and filled with oil and marvels, i noticed a little leak on the pas. side cam cover. so i replaced the cam cover gasket, then i noticed that little hose from the tstat to the block had that little puncture. i replaced that and started her up, i'm still getting white smoke from under the engine. it seems to start from where the oil was leaking from the cam cover but cant tell. as i type this i am waiting for the engine to dry, i just used degreaser again. i will try again and see if i am still having this problem. has anyone else had this problem? thanks in advance Tibia Quote Link to comment Share on other sites More sharing options...
Indrid cold Posted December 15, 2006 Share Posted December 15, 2006 earlier post said to spray area with a powder deoderant after engine is clean and dry and it will collect where the oil leaks from forming a trail... I am about to do what you just did so no first hand experience yet as I am still pouring a quart of oil in and leaving a trail down the road:grin: Quote Link to comment Share on other sites More sharing options...
nipper Posted December 15, 2006 Share Posted December 15, 2006 It doesnt take much oil redidue to make the car smoke. After i had my engine rebuilt, car smoked for 50 miles till everything burned off (50 highway miles). I wouldnt get too excited by it, give it time to burn off. nipper Quote Link to comment Share on other sites More sharing options...
Tibia Posted December 15, 2006 Author Share Posted December 15, 2006 well, after cleaning and looking at it time after time the smoke seams to be coming from the cat. like something is dripping on it. i took her for a little test drive around the block and besides from not having any balls (assuming its the ign. timing that i never took care off) when i pulled back in it was smoking up a storm, still no sign of oil. it doesnt look like its coming from the trans axle. i did notice the tranny fluid was really low. oh i forgot to mention when i stopped the oil pressure dropped way down almost nothing well i guess ill take another look in the morning Quote Link to comment Share on other sites More sharing options...
nipper Posted December 15, 2006 Share Posted December 15, 2006 oh i forgot to mention when i stopped the oil pressure dropped way down almost nothing it's always the little details they leave out.... nipper Quote Link to comment Share on other sites More sharing options...
hatchsub Posted December 15, 2006 Share Posted December 15, 2006 Well i dont know how the engine and the exhaust are routed on an EA82 but when i had oil leaking and burning off on a cat in my EA81 it ended up being the rear main seal. Also my oil pressure would drop down way low when i had this problem. Quote Link to comment Share on other sites More sharing options...
heartless Posted December 15, 2006 Share Posted December 15, 2006 the stock oil pressure gauge is not known for being very accurate (none of the stock guages are all that accurate on these), but it is common to show little or no pressure on a warm engine at idle. what is the pressure running at speed? mine runs a bit over 45 when oil is properly filled at about 60 mph. Quote Link to comment Share on other sites More sharing options...
Tibia Posted December 18, 2006 Author Share Posted December 18, 2006 Oil pressure has returned to 'normal'. At 1500 we're seeing 80 psi on the gauge. Drops down to 35 or so when at 700 idle. Will keep an eye on it just in case. Finaly found where the oil smoke is coming from... from inside the bolt-on covers surrounding the exhaust pipes, from the exhaust manifolds to the cat. Any ideas of what we'll find once the covers are removed, ie fiberglass packing, etc ? Do these covers serve any purpose ? Tibia Quote Link to comment Share on other sites More sharing options...
joostvdw Posted December 18, 2006 Share Posted December 18, 2006 Oil pressure has returned to 'normal'. At 1500 we're seeing 80 psi on the gauge. Drops down to 35 or so when at 700 idle. Will keep an eye on it just in case. Finaly found where the oil smoke is coming from... from inside the bolt-on covers surrounding the exhaust pipes, from the exhaust manifolds to the cat. Any ideas of what we'll find once the covers are removed, ie fiberglass packing, etc ? Do these covers serve any purpose ? Tibia they're heat shields, and, they shield heat inside there is some sort of fiberglass yeah, I removed the shields from the cat on my XT and found dozens of rust pinholes, out of these pinholes watery substance sprayed on the cat and burned off, causing smoke. Quote Link to comment Share on other sites More sharing options...
nipper Posted December 18, 2006 Share Posted December 18, 2006 ALso if you do take the car off roiad, it helps to keep from starting fires. You can remove them, but the ones around the cat should be replaced. nipper Quote Link to comment Share on other sites More sharing options...
Tibia Posted December 18, 2006 Author Share Posted December 18, 2006 alright, i will be taking them off today and will see what happens. thanks for the help Quote Link to comment Share on other sites More sharing options...
