Pull the battery cable for 45 minutes or pull the ECU fuse for 45 minutes.
Put the car in neutral, put the ebrake on, put the fuse or cable back on, and start the car. Let it get to running temp or 10 minutes - whatever comes first. Then shut the car off. Do not touch the gas or anything.
Or the factory manual method:
Igniton - OFF
Connect the black and green connectors under the steering column. Both are single wire, normal-state is disconnected.
Igntion - ON
Press the throttle to the floor.
Lift it back to approx. half-way, hold it there for 2 seconds.
Release throttle fully.
Ignition - START!
Let the engine run for a few seconds, the CEL will be off if there are no present faults.
Start driving....sooner or later, within minutes, the CEL will flash at a steady rate, indicating the ECU is reset.
Igntion -OFF
Disconnect both green and black wires.
DONE!
