flyjum Posted December 15, 2006 Share Posted December 15, 2006 Well I was replacing my HG's and well the block and head are #&*@ed up. The passenger side block and head have a bad chunk taken out of it. Its between the water jacket and the combustion chamber. Ill post pics later. Well thats why the HG's have been changed like 4 times before i bought the car. So I guess Im going to swap a EJ in with a 5 or 6 speed most likely only RWD. Bad rump roast that I only have 100 bucks into the car. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted December 25, 2006 Share Posted December 25, 2006 Can´t be Done a Repair?, Have you Pics? Link to comment Share on other sites More sharing options...
NoahDL88 Posted December 25, 2006 Share Posted December 25, 2006 Pics of block and head carnage please!! Link to comment Share on other sites More sharing options...
Phizinza Posted December 26, 2006 Share Posted December 26, 2006 So I guess Im going to swap a EJ in with a 5 or 6 speed most likely only RWD. If you use a AWD EJ gearbox you are going to have to weld the center diff. If you just use the 5sp D/R and a non turbo EJ it should be fine. I've heard the EA 5sp's can't take turbo EJ's, but after looking in my D/R EJ (yes, in Aus we got D/R EJ gearboxes) I found pretty much everything in it is interchangable. So if the S/R EJ boxes are the same as my D/R it should be able to take a early WRX engine I would think. Of cause, fitting a early model WRX gearbox isn't to hard, just have to play around with DOJ cups and CV's and make a new gearbox crossmember. Plus some linkage stuff. Might be cheaper that way if you don't want to make or buy the adapter plate, flywheel and maybe custom clutch. I still think the hardest thing with putting a EJ (even with the gearbox) in a EA is the wiring. Good luck, and give us updates when things start to come together. EDIT: Sorry, my bad, no need if only RWD... Link to comment Share on other sites More sharing options...
