Oil pump seals
There's no real tricks to it. You remove the timing belts, and take out the 4 or 5 10mm bolts that hold the pump to the block. There's two seals on the pump, you clean the mating surfaces and reinstall. Takes about the same time as any other timing belt removal type job (front main, water pump, cam seals, etc) - about 2 to 3 hours if you have the covers in place, and about 20 minutes if you don't.
