Caboobaroo Posted December 17, 2006 Share Posted December 17, 2006 I was wondering guys/gals if an intake from an EJ20G would work on an EJ20K engine? I've heard that it won't as far as the bolt holes being different but the person wasn't 100% sure on it. I'm planning on dropping an EJ20K into my '87 EA82 coupe this spring and have sourced the engine a couple hours from me. Guy says that he has the intake from the "G" engine since the intake from the "K" engine is no longer there. Does it depend on the years of the engines? Link to comment Share on other sites More sharing options...
Dr. RX Posted December 18, 2006 Share Posted December 18, 2006 I was wondering guys/gals if an intake from an EJ20G would work on an EJ20K engine? I've heard that it won't as far as the bolt holes being different but the person wasn't 100% sure on it. I'm planning on dropping an EJ20K into my '87 EA82 coupe this spring and have sourced the engine a couple hours from me. Guy says that he has the intake from the "G" engine since the intake from the "K" engine is no longer there. Does it depend on the years of the engines?Nope, won't work unless you change the turbo also. On the 'G' the turbo inlet takes a 90 degree bend between the intake and the turbo, on the 'K' engine the turbo inlet goes underneath the intake manifold then take the 90 degree bend in front of the manifold. Link to comment Share on other sites More sharing options...
Caboobaroo Posted December 18, 2006 Author Share Posted December 18, 2006 well I have the turbo situation figured out. I have a TD04 which I know doesn't have the 90 degree inlet BUT I have piping from my RX (when I had the TD04 on the EA82T) that would make it work. Pictured here Would that still work? I'm pretty sure that the TD04 has the same exhaust inlet as the stock turbo for that engine (VF11 or something like that?). If it does, then I'm also planning on using the 3" bellmouth downpipe I have for the TD04 as well:brow: Link to comment Share on other sites More sharing options...
Dr. RX Posted December 18, 2006 Share Posted December 18, 2006 well I have the turbo situation figured out. I have a TD04 which I know doesn't have the 90 degree inlet BUT I have piping from my RX (when I had the TD04 on the EA82T) that would make it work. Pictured here Would that still work? I'm pretty sure that the TD04 has the same exhaust inlet as the stock turbo for that engine (VF11 or something like that?). If it does, then I'm also planning on using the 3" bellmouth downpipe I have for the TD04 as well:brow: Yes, that setup should work. Link to comment Share on other sites More sharing options...
Caboobaroo Posted December 19, 2006 Author Share Posted December 19, 2006 sweet! Thanks Corky for clearing that up for me:clap: Link to comment Share on other sites More sharing options...
