EA swap questions
I believe that the carbs are different between the 79 and the 81, not 100 on that though.
Which boots specifically are "exploding"
Sorry, no help on the radiator, but any EA-81 radiator should work, so that opens you up to quite a few more options.
well i dont have a camera at the moment. but i need that deal that connects to a pump and a butterfly valve in the carb. it is usally a round shape and it had a coil type spring in it. it connects right next to the air intake port on the carb. do ya know what im talkin about? well mine is busted and just hangin there.
I think I know, I'll check the carb and see if it's there.... I'll let you know tomorrow, it's across town right now.
