njdrsubaru Posted December 21, 2006 Share Posted December 21, 2006 Hey Guys Ok I have a buyer for my legacy wagon and ia m replacing it with a 93 Impreza AWD Auto EJ18, Are the EJ18s as reliable as the EJ22s? Do they essentially share the same trasnmission components? Is it a different beast than the legacy? or should i look for the same problems when buying it? thanks Neo :cool: Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted December 21, 2006 Share Posted December 21, 2006 They should be roughly the same/similar. There are probably going to be some differences, but shouldn't be much. Quote Link to comment Share on other sites More sharing options...
DerFahrer Posted December 21, 2006 Share Posted December 21, 2006 The EJ18's are just as, maybe more, reliable than the EJ22 which they're based off of. The two engines are virtually IDENTICAL except for the bore. Quote Link to comment Share on other sites More sharing options...
WoodsWagon Posted December 21, 2006 Share Posted December 21, 2006 The EJ18 is hardly ever talked about here, because it's reliable I believe. The only time you hear about them is when someone's taking out a perfectly running one to put an EJ22 in for more power. Quote Link to comment Share on other sites More sharing options...
edrach Posted December 23, 2006 Share Posted December 23, 2006 Here's what came up with a search for EJ18 reiliability (of course it helped that I had replied to it and knew it had to be there): http://www.ultimatesubaru.org/forum/showthread.php?t=67752&highlight=EJ18+reliability Quote Link to comment Share on other sites More sharing options...
