Prospeeder Posted December 21, 2006 Share Posted December 21, 2006 Ah.. ok so my intakes on, and i barley got that stupid EGR pipe in, and it took me aLOT of times of trying and adjusting the pipe to get the stupid nut the thread, and it went in, but only like 1/3 mabye 1/2 the way in, and stopped, and to me it looks abit crooked, im super afriad i crossed it but its not spinning, its tight, but if it leaks, and i crossed the threads, what can i do??? i dont know the thread, pitch, or nothin. there some pretty heavy coarse threads, i hate aluminum..... Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 21, 2006 Share Posted December 21, 2006 You should always thread the EGR pipe in BEFORE you lock down the manifold. If it leaks you just get an exhaust leak under your hood. GD Quote Link to comment Share on other sites More sharing options...
Prospeeder Posted December 21, 2006 Author Share Posted December 21, 2006 damn i wish some1 woulda told me that im afriad if i loosen the manifold that it will ruin my new gaskets, since iv ran the car. Is it possible to do it with the manifold bolted down.... Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 21, 2006 Share Posted December 21, 2006 They will come off clean till it's been ran for a few weeks. It takes a while for them to bond usually. As for with the manifold on.... from what I remember of my first time, I had to loosen it. GD Quote Link to comment Share on other sites More sharing options...
Prospeeder Posted December 21, 2006 Author Share Posted December 21, 2006 alright then, thanks, i guess ill take the bolts out, and lift it up, does it need to raise alot to get it to thread in?? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 21, 2006 Share Posted December 21, 2006 alright then, thanks, i guess ill take the bolts out, and lift it up, does it need to raise alot to get it to thread in?? I just always leave the EGR pipe on the manifold. Then thread it into the head when I'm installing it. I never have any trouble doing it that way. GD Quote Link to comment Share on other sites More sharing options...
Prospeeder Posted December 24, 2006 Author Share Posted December 24, 2006 ok the threads are crossed, what do i do..... and if i do have to retap it or helicoil it what size is the thread and everything?? Im not too enthused, i feel stupid for crossing it Quote Link to comment Share on other sites More sharing options...
Prospeeder Posted December 24, 2006 Author Share Posted December 24, 2006 also they are not damaged much, looks like only a small portion are messed up, so would chasing the threads possibly work, its only the begining thats damaged, not deep into it. So what size chaser would i use?? Quote Link to comment Share on other sites More sharing options...
NorthWet Posted December 24, 2006 Share Posted December 24, 2006 I would go ahead and chase the threads. Its a relatively big fitting for the mechanical stresses on it, so it is not like the threads will be physically strained retaining the tubing. Quote Link to comment Share on other sites More sharing options...
Prospeeder Posted December 25, 2006 Author Share Posted December 25, 2006 i dunno where to find a chaser that large, i went to the parts store and they said they didnt have anything nearly that big Quote Link to comment Share on other sites More sharing options...
NorthWet Posted December 25, 2006 Share Posted December 25, 2006 Too dark/wet/cold for me to go out and look right now, but is it bigger thread than spark plugs? They might have used the same threading. Quote Link to comment Share on other sites More sharing options...
Prospeeder Posted December 25, 2006 Author Share Posted December 25, 2006 oh maybe, it seems to be a more coarse thread than the plugs, but im thinkin about the same in diameter, should i try and see if the plug matches up or threads in? if anyone has any ideas lemmie know, espeically on the size of chaser i should get. Im thinkin like 18? or is that really big, maybe 14? Quote Link to comment Share on other sites More sharing options...
NorthWet Posted December 25, 2006 Share Posted December 25, 2006 If it happens to be the same size as a sparkplug (and, BTW, the same as an O2 sensor), sparkplug chasers are commonly available and cheap (usually double-sided...18mm/14mm???). Quote Link to comment Share on other sites More sharing options...
baccaruda Posted December 25, 2006 Share Posted December 25, 2006 IIRC it's larger diameter and the thread is coarser as well. Make sure that the pipe doesn't have any bracketry holding it to the engine or holding something else to the pipe.. I don't recall if there is anything. Try loosening the pipe at the engine and then remove the pipe from the manifold.. get it threaded properly into the manifold by observing the direction in which it feels misaligned, then leverage the pipe away so that you can feel less resistance when turning the nut in.. and push the pipe straight into the fitting. You want to pressurize it positively. Pushing it straight into the fitting will help to pull it in the proper direction to fit straight. You should be able to see if the nut is parallel or misaligned while threading it in. You may have to adjust and push the pipe in and straight if it feels to bind up. Then thread it into the engine afterward as GD says it's the easier connection. You may have to pressurize that fitting as well. Quote Link to comment Share on other sites More sharing options...
TomRhere Posted December 25, 2006 Share Posted December 25, 2006 What I would do is remove the tube intirely from the engine, just so I could get a better look at the threads in the head. "If",,, they're not to messed up, you may be able to use a narrow straight-blade screwdriver to "chase" the threads. Patience is a requirement, slow and easy is the method. You are trying to remove the burrs on the original threads put there by the cross-threading. Once you have most of the burrs removed or smoothed down, try to start the fitting in. Baccaruda's suggestion of some down-force on the nut could be of benefit. Just be sure you have it straight with the threads, or you'll be right back where you are now. I have done that to threads in steel and in cast iron, so it should work on aluminum. Just have to be patient, and be mindfull of what you're doing, Can't be in a rush, nor can you go at it like you're chopping wood. Quote Link to comment Share on other sites More sharing options...
Prospeeder Posted December 25, 2006 Author Share Posted December 25, 2006 it is slightly larger, with coarser threads. Thanks for the suggestions, its stripped at the manifold, not the head btw, and the manifolds off, so does the other end of the pipe just go to an exhaust pipe, manifold, or actually the head? Cause if its just out in the open easy to take off the head or what ever then i can try that way. is the screw driver idea ok? like do i start in a good thread and just carfully follow the thread and follow it reshaping the threads sorta deal Quote Link to comment Share on other sites More sharing options...
baccaruda Posted December 25, 2006 Share Posted December 25, 2006 I respect others' suggestions to chase the threads, but if it's not too far in there, I wouldn't bother, as the threads are so coarse that they'll self-correct if you can get it to line up straight. wait, if the manifold's off the car, then yeah, inspect the threads... and maybe just get a new manifold if they're chewed up. Quote Link to comment Share on other sites More sharing options...
Prospeeder Posted December 25, 2006 Author Share Posted December 25, 2006 ha anyone gonna send me a manifold, lol..... no yards here have turbos so you do think i can just self correct it, its the very first threads that are messed up. i can try Quote Link to comment Share on other sites More sharing options...
ShawnW Posted December 25, 2006 Share Posted December 25, 2006 Go to the junkyard and get another couple of EGR pipes. On One Chop the pipe so the threaded end can fall off. Put grooves into the threads to create a tap. Place your 17MM socket onto the EGR threaded end and run it into the hole and out a couple times to clean the threads. Install the 2nd pipe you got at the junkyard onto the engine. A little PTFE teflon in a tube (plumbing section of hardware/home improvement store) will help keep it from leaking. Quote Link to comment Share on other sites More sharing options...
Prospeeder Posted December 26, 2006 Author Share Posted December 26, 2006 Alright! I got it, My dad used the dremel and sanded down the bad threads, and kept the good ones, and the thing went in and threaded right up and seated. But the knock sensor wires broke off, LOL one thing after another, but they might have been causing some major problems with driving, only like 1-2 strands of wire were holding them on at the base, and they finally broke, so im gonna put new wiring for it. Thanks for the help everyone! Quote Link to comment Share on other sites More sharing options...
NorthWet Posted December 26, 2006 Share Posted December 26, 2006 Alright! I got it... Congrats!!! Quote Link to comment Share on other sites More sharing options...
