i got a 95 legacy l a/t wagon
As long as you think everything is up to snuff (including the cupholder!) you should be good to go. '95 is a great year . . . yes, I'm prejudiced!
How many miles on it?
look for torque bind. the 95 and 96 could have some hidden in the tightest turns. (all the way, lock to lock). i had some minor in my 95 when i bought it . thought it was standard. it only gets worse.
the seat, if the previous ownr was heavy, the seat may sag lower than usual. ?
door locks?
Please don't take the owners word for it,as suggested before take it out and test it yourself.Might sound like a good deal now but 2 months from now replacing the pack because of TB won't taste so well. Of course finding out before may enable you to drive the price way down at least enough to cover yourself if you have to front those expenses. John
got the 95 l legacy a/t wagon bought and home, my question is what years will fit on my 95 legacy + since the l model has no map light is there wiring there and screw holes to put one there
95 - 99 are the same body / chasis styles. doors form one will fit the other, etc. the 99 engine had some slight differences, 95 2.2 swap into a 99 2.5 is not as easy as into a 97 or 98. the a/t was the beginning of the 4eat phase 2, it has the spin on exterior trans filter.
but all body parts should swap. and the agreement here is that the wiring harness is the same for the limited as it is for the brighton. so enjoy.
