SuBrat84 Posted December 23, 2006 Share Posted December 23, 2006 So I was giving it some thought... how hard would it be to use SPFI from a 91 loyale (ea82) on my ea81 (hydro)? Do I need any special adapters? I should get some kind of new gaskets, right? Maybe you guys could point me to a good thread or two about it? Any stuff I need custom or new? Is it hard to work out the vacuum routing? What about the computer? Thanks everybody!! I sure would like to have my brat fuel injected to go along with that 5spd and rear lsd Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 23, 2006 Share Posted December 23, 2006 You can read my write up on it here: http://home.comcast.net/~trilinear/EA81_SPFI.html GD Link to comment Share on other sites More sharing options...
Phizinza Posted December 23, 2006 Share Posted December 23, 2006 Been much talk about it on here lately. You should be able to find some info with a search like "SPFI EA81" I would think.? Diffinatly read GD's write up, it's very informative. Link to comment Share on other sites More sharing options...
SuBrat84 Posted December 23, 2006 Author Share Posted December 23, 2006 After I posted this thread I used the "Similar Threads" feature to locate some good threads, and did find and read most of the write up. Good stuff! The loyale has a silver computer. Doh! And I already got rid of the pedal assembly! Double Doh! So I would need to source out a black computer from an 87-89 ea82, right? Would that still work okay if the rest of the parts came from the loyale still? or would I need the wiring harness / disty with that computer? 2wd okay? I could get it at the JY most likely. What about like intake gaskets, etc? Is all of that info available on your wonderful write up? Thanks! -Eli- You can read my write up on it here: http://home.comcast.net/~trilinear/EA81_SPFI.html GD Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 23, 2006 Share Posted December 23, 2006 Should all be in there, yeah. The black ECU should work fine with the loyale wireing. Just make sure you get an ECU from a 5 speed (2WD or 4WD - doesn't matter). GD Link to comment Share on other sites More sharing options...
