NoahDL88 Posted December 24, 2006 Share Posted December 24, 2006 So, with Impreza hubs and FWD axles, i have all the fit issues taken care of, but it seems like the axles are being pushed together, as if there too long, anyone else have this problem? Link to comment Share on other sites More sharing options...
Numbchux Posted December 24, 2006 Share Posted December 24, 2006 hmmm...when I had those FWD impreza axles, I compared them to an EA82 axle, and they looked to be the same size... so, the only thing I can think of is that they might not be pulled all the way through the axles? Link to comment Share on other sites More sharing options...
NoahDL88 Posted December 24, 2006 Author Share Posted December 24, 2006 Used an impact, so i'm pretty sure there all the way through :-\ Link to comment Share on other sites More sharing options...
Numbchux Posted December 24, 2006 Share Posted December 24, 2006 Used an impact, so i'm pretty sure there all the way through :-\ rats....I just don't know man. that doesn't seem right Link to comment Share on other sites More sharing options...
Dr. RX Posted December 24, 2006 Share Posted December 24, 2006 The data that I have seen shows the Impreza axles are 4mm longer, I really don't think 4mm is going to make a big difference, since there is more the 2mm play in either direction at each joint. Link to comment Share on other sites More sharing options...
NoahDL88 Posted December 24, 2006 Author Share Posted December 24, 2006 Thats good news. It seems like its only a problem on the drivers side, when i push in the top of the knuckle to bolt it to the strut, it was really hard to get the holes to line up, and it seemed like it was the axle that was limiting the inward travel. I guess i'll go through it again and see what i can find. Link to comment Share on other sites More sharing options...
baccaruda Posted December 25, 2006 Share Posted December 25, 2006 I installed the bottom control arm bolts last and I honestly have to say it was one of the most difficult things I've had to do in a while. If you had your control arm bolts in before the struts/knuckle bolts then your difficulty would have been similar to mine as it was your last point to close. I think it's because I have taller Legacy struts with WRX springs on the front of mine; it looks to ride pretty high in front. I will be using a spring compressor on the struts whenever i have to take the front end apart as it will facilitate the the proper seating of the control arm bushing; it was sitting in the crossmember bracket sort of swiveled out, pivoted as from the strut rod bushing. Link to comment Share on other sites More sharing options...
NoahDL88 Posted December 25, 2006 Author Share Posted December 25, 2006 I'm gonna throw it on the alignment rack at work, and see if its just the fact that my toe is way out. After that i'm out of ideas. Link to comment Share on other sites More sharing options...
baccaruda Posted December 25, 2006 Share Posted December 25, 2006 could be that as well.. my toe looked straight until i put the control arm bolts in (last), then i had to readjust the toe. Consider the spring compressor as well though.. good luck! I'm gonna throw it on the alignment rack at work, and see if its just the fact that my toe is way out. After that i'm out of ideas. Link to comment Share on other sites More sharing options...
NoahDL88 Posted December 25, 2006 Author Share Posted December 25, 2006 Everthing is connected, it was just a bear to get the drivers side together. Link to comment Share on other sites More sharing options...
idosubaru Posted December 28, 2006 Share Posted December 28, 2006 why was it harder to get in on that side? just the axle issues alone? other than that the impreza axle's worked for you just fine? no swapping joints or anything? Link to comment Share on other sites More sharing options...
NoahDL88 Posted December 28, 2006 Author Share Posted December 28, 2006 I used, impreza FWD axles, with Imp hubs brakes and knuckles, the struts were random EJ with EA hats, and the ball joints are EJ i believe with the XT-6 control arms. When i was lining up the bolt for the camber adjust bolt, it seemed like there was something holding it out, and i can't figure out what it is, the strut isn't hitting anything so i'm pretty sure its not that, when i did an axle on my legacy it went in just fine, i dunno, i'm gonna align it some time this year, and then go from there. Link to comment Share on other sites More sharing options...
