oil pump o-ring?need advice fast.....
hey guys
The oil pump o-ring on the 96 2.5 legacy
I have the engine overhaul gasket set
There is one o-ring that looks close to the correct size but seems a little small in the diameter (does not look like the proper fit)
Then, there are 4 identical o-rings that look like they fit much better
but 2 things...why 4? and it is not true o-ring...it sort of has a small molded lip in the ID
Can anyone tell me with certainty what is what???
Thanks
Bill
I can't see how a little sealant or as mentioned grease on it to hold it in place while the pump is fitted is going to hurt. The biggest problem I had was yes the o-ring is a little loose in the groove. On the first attempt it fell out and I didn't notice it. Fortunately I pulled the pump off to double check and saw it. A bit of grease or something to hold it in place would help.
Do they happen to have a part number on them or is it just a big bag of parts? The o-ring I used was 10991AA001 but this was on an '00.
Porcupine
no P/n's with the gaskets in the kit
Perhaps I will have to go to stealership and ask and then report back to group
Thanks for all the input
Bill
Porcupine
Bill
Well...went to stealer...he pulled an o-ring out of a larger package (individual o-ring was not in it's own bag.....it has a purplish color to it...seems to be the same diameter as the 4 funky looking -rongs that came with my engine gasket set....p/n is 806919050...?
so....i figured I'd buy it to be safe...friggin thing was 6.61 with tax....crooks
I still don't understand why the 4 o-rings in my set were not 0-rings in the true sense of the term (a had sort of molded lip on the ID)
i think the term o-ring referrs to the circular shape not the cross section .
you may be right...but I always thought an 0-ring was circular in cross section ...anything else would be a "gasket" ....I have worked for a rubber company for 25 years
The number is correct and yes they're crooks because even the list price is around $2. The lip is just the mold line, they had to put it somewhere.
No....I know a mold parting line (I'm in the rubber business)....this is a molded lip of sorts on the OD of the o-ring
If I had access to a digi camera I would cut the o-ring and ake a close up and post it...maybe during the upcominig week
