moosens Posted December 26, 2006 Share Posted December 26, 2006 THIS IS ABOUT A TRANNY THAT LOCKED UP,NOT A Locking diff.... That's a single range EA82T with the pushbutton atop the shifter. Tranny locked up like you'd see in a cartoon.1/8+ inch of rubber for about 40 ft. Shifter linkage was loose.Had been waiting for AAA,got pissed and tried to take off on my own after hooking the link over without the bushing and lock nut.I was foolish,I know,but I'd driven about 60+ miles already and only had a few miles to go,and was pissed at AAA for making me sit for 1 1/2 hours and watching the sun go lower and lower. So,it seems there may have been two gears selected at once. There's an outside chance that it was so low on gear oil that it may have seized but there wasn't any high pitched squealing beforehand.The level was very low,but I've driven my '78 quite low before too. Car was going forward.I had just shifted from 2nd to 3rd,let the clutch out and maybe got a few feet and BAM! I must have lost the nut and shifter link bushing just down the road from where I pulled over to drain some coffee.Went to put it in reverse and the shifter came loose.That was the begining of it all. Good thing I had that EJ22 in the cargo area well lashed down.Amen!That literally WAS my Christmas present.Also lucky that it locked up on a country backroad in eastern CT and not down here in the rat race.Double AMEN!!More hair on my body now,for sure.Hope it never happens to one of you folks. OK,I pulled you this far.Now,what do you think about being able to break it loose and it still being good? Link to comment Share on other sites More sharing options...
Turbone Posted December 26, 2006 Share Posted December 26, 2006 Yowsers, that must have been a rude awakening:eek: I think if you jack the front end up and work the linkage while rotating the whells, it might unlock. Then you can see if the gears are ripped up or not. Dont forget the grease:brow: Link to comment Share on other sites More sharing options...
moosens Posted December 26, 2006 Author Share Posted December 26, 2006 Front wheels won't rotate at all right now.:-\ Link to comment Share on other sites More sharing options...
WoodsWagon Posted December 26, 2006 Share Posted December 26, 2006 As one who has grenaded many rear ends and a couple of trannys (not this one yet...) If the wheels are jammed, and neither wheel will turn with both the front wheels off the ground, I'd say you have a lot of broken pieces stuck in the diff. I've had good luck with dragging vehicles the opposite direction till the shards pop back out of the gear teeth, draining the fluid and chips, and refilling. Link to comment Share on other sites More sharing options...
NorthWet Posted December 26, 2006 Share Posted December 26, 2006 91Loyale said: As one who has grenaded many rear ends and a couple of trannys (not this one yet...) If the wheels are jammed, and neither wheel will turn with both the front wheels off the ground, I'd say you have a lot of broken pieces stuck in the diff. I've had good luck with dragging vehicles the opposite direction till the shards pop back out of the gear teeth, draining the fluid and chips, and refilling. Agreed with checking this to determine diff/final drive vs gearbox proper. The one time I had a transaxle jam up, the bearings supporting the final drive (it was a transverse layout, so no R&P per se) disintegrated. Link to comment Share on other sites More sharing options...
idosubaru Posted December 26, 2006 Share Posted December 26, 2006 well i'm of no help here, but how did the loose shifter cable cause this? i'm trying to understand what happened, since i'm a little weak on manual trans stuff. Link to comment Share on other sites More sharing options...
kayakertom Posted December 26, 2006 Share Posted December 26, 2006 Went through something similar: http://www.ultimatesubaru.org/forum/showthread.php?t=62027 I followed the advice of Rguyver and Nug and did aggressive shifts from R to 1st and it freed up. If you suspect internal damage, then I would drain trans oil and look for metal. Link to comment Share on other sites More sharing options...
idosubaru Posted December 26, 2006 Share Posted December 26, 2006 neat thread kayakertom - has it driven fine since them? no reoccurences? Link to comment Share on other sites More sharing options...
kayakertom Posted December 26, 2006 Share Posted December 26, 2006 The trans shifts very smoothly through the gears and going into 4wd with the hi/lo selector has gone from being very difficult to engage / disengage to easy fingertip control. I'm very happy with the car now - lots of fun to drive. grossgary said: neat thread kayakertom - has it driven fine since them? no reoccurences? Link to comment Share on other sites More sharing options...
moosens Posted December 27, 2006 Author Share Posted December 27, 2006 grossgary said: well i'm of no help here, but how did the loose shifter cable cause this? i'm trying to understand what happened, since i'm a little weak on manual trans stuff. Not a cable,the hard linkage where there's a large loop at the end,has bushings,nut on the end of the link rod secures it all to the tranny. I really think it's because 2 gears got selected at once.We'll see.We're definitely trying to break it loose first before doing any take down.Naturally,I'll be draining the chips,etc.....but thanks for making sure. You know,it;s these 2 1/2 year projects with interuptions that really suck.I should have been all over the underside making sure everything was snug,etc. I'm guessing I barely toqued the nut on by hand just to get it towed from the old workshop and just neglected to get back under there.I don't know....but we'll find out if she'll break loose soon.Going to be a fun day,I'm sure.:-\ Link to comment Share on other sites More sharing options...
moosens Posted December 30, 2006 Author Share Posted December 30, 2006 Quote Can a locked front diff be unlocked? YES!! Thanks guys!! Great advice. 1st to Reverse,seemed to loosen it up. Drove it home about 80 miles on motor oil.Going to drain,refill,check the fragments,etc. Link to comment Share on other sites More sharing options...
moosens Posted December 31, 2006 Author Share Posted December 31, 2006 Drain result: Mostly a metalic silt at bottom of pan with a few fragments of gear teeth.No real chunk of tooth.Motly the fragments looked like shavings off the gear teeth.Motor oil I used as gearbox lube to get home was quite blackened :-\ .Magnet on the drain plug held mostly silt,a pinch of metal "hairs",and a couple of shavings.Again,no real chuncks. Added a full 3qts. of 80W90 and the reading still looked on the low side.Going to make a little run tonight and check it again,probably in the morning.Driver's manual said it should take 2.7 qts. ....hmmmm. Going to do another drain.I just don't feel that great about it although it sounds much better and behaves very well. Only problem: Not catching 5th cleanly or sometimes just not at all and I throw it back into 4th in frustration and fear of it grenading.I managed to get 5th on the long ride home with the motor oil in the gearbox.Seemed to get worse after the drain/refill with the proper gear oil. Could I have slightly bent the shifter fork when I was struggling with it while the shifter was working loose all that time?Or do you think it's more likely the 5th gear synchro worn too much to help? Link to comment Share on other sites More sharing options...
kayakertom Posted December 31, 2006 Share Posted December 31, 2006 If it is the 4wd trans, then its capacity is 3.5 quarts. Might consider making up the difference with auto trans fluid. Link to comment Share on other sites More sharing options...
moosens Posted December 31, 2006 Author Share Posted December 31, 2006 kayakertom said: If it is the 4wd trans, then its capacity is 3.5 quarts. Might consider making up the difference with auto trans fluid. I'll look again,but I swear my DM said 2.7 for the S/R 5spd.Been wrong once or twice before,so we'll see. Yeah,maybe the tranny fluid thing,drive it around,then drain and refill.Didn't use the car tonight.Will make the New Years Eve food run and do it then. Happy New Year all you fellow Suba-cretins! Link to comment Share on other sites More sharing options...
moosens Posted December 31, 2006 Author Share Posted December 31, 2006 Yup,you were right,it's 3.5 qts. US So,I did the tranny fluid thing,drove it a bit,drained it.WOW,took a lot more silt with it and ouch! :-\ some crunchy stuff today.Definitely most of a geartooth face is missing,maybe two,more...??? 5th gear doesn't want to engage,hurting synchro for sure. Otherwise not bad to drive at all.Going to go for another tranny though since there's two in the northeast,one not too far. Link to comment Share on other sites More sharing options...
