1Subaru1 Posted December 27, 2006 Share Posted December 27, 2006 I'm going to look at puchasing a 1999 Brighton Wagon SE, 2.2L, auto, air, cruise, p.m.,p.w., with 165000 kms on it. What things should I be inspecting, or make sure the independent mechanical inspection covers? The more detail the better. One thing I know is: routine maintenance records are important. The car is in northern Ont., Canada. Any help would be appreciated.Thanks. Quote Link to comment Share on other sites More sharing options...
ericem Posted December 27, 2006 Share Posted December 27, 2006 I'm going to look at puchasing a 1999 Brighton wagon, 2.2L, auto, air, cruise, p.m.,p.w., with 165000 kms on it. What things should I be inspecting, or make sure the independent mechanical inspection covers? The more detail the better. One thing I know is: routine maintenance records are important. The car is in northern Ont., Canada. Any help would be appreciated.Thanks. be sure to look at the fluid levels, leaks, check out the transmission fluid and make sure its red, not brown, or smelling burnt. Look around the vehicle for rust,and such. Inspect all the CVD's for broken boot. But its a good suggestion to bring the car to a mechanic to inspect the vehicle. There is much more, like make sure there is no CEL(Check Engine Light) or trans oil temp light, and make sure the car does not over heat at all. Also ask for records of timing belt change,and/or oil changes or repairs, and be sure to do a VIN number check. Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted December 27, 2006 Share Posted December 27, 2006 i guess the original owner could have bought optional power options, but in the US i thought the brighton had no power options except power steering. your car sounds more like a legacy L; but then i'm not terribly familiar with the 99MY and much less so with the canadian market. does it have a tachometer? read this thread. http://www.ultimatesubaru.org/forum/showthread.php?t=69202 john I'm going to look at puchasing a 1999 Brighton wagon, 2.2L, auto, air, cruise, p.m.,p.w., with 165000 kms on it. What things should I be inspecting, or make sure the independent mechanical inspection covers? The more detail the better. One thing I know is: routine maintenance records are important. The car is in northern Ont., Canada. Any help would be appreciated.Thanks. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted December 27, 2006 Share Posted December 27, 2006 In addition to the good things already mentioned, make sure the FWD fuse is not installed and check for torque bind. Quote Link to comment Share on other sites More sharing options...
WoodsWagon Posted December 27, 2006 Share Posted December 27, 2006 Check the rear crossmember, the part that hold the diff and lower links to the body, for rust. Give it a couple of pokes if it looks suspicious. Quote Link to comment Share on other sites More sharing options...
1Subaru1 Posted December 30, 2006 Author Share Posted December 30, 2006 :banana:Thanks for all the advice guys, and to this Subaru site. I purchased the Brighton Wagon, after a test drive and an inspection by Subaru of Sudbury. They said it was solid and looked good in all of the right places.They let me go into the service bay to see the underside of the car too.So now I'm the proud owner of a Subaru. :clap:Hopefully I'm not on here too often trying to figure out how to fix things. I'm off, I have a manual to read! Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted December 30, 2006 Share Posted December 30, 2006 congratulations and welcome to the party!!!! :banana::banana: :banana:Thanks for all the advice guys, and to this Subaru site. I purchased the Brighton Wagon, after a test drive and an inspection by Subaru of Sudbury. They said it was solid and looked good in all of the right places.They let me go into the service bay to see the underside of the car too.So now I'm the proud owner of a Subaru. :clap:Hopefully I'm not on hear too often trying to figure out how to fix things. I'm off, I have a manual to read! Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted December 30, 2006 Share Posted December 30, 2006 Congratulations, sounds like a good buy. Resistance was futile; you have been assimilated. Quote Link to comment Share on other sites More sharing options...
1Subaru1 Posted December 31, 2006 Author Share Posted December 31, 2006 Well, I picked her up this afternoon. She ran like a charm from Sudbury to Muskoka (2.75 hrs.) and I couldn't be happier! I love this car!:clap:Off to the dealer to get a couple of things looked after. The oil pump gasket has a small leak so I figure I'll get the timing belt done, water pump and oil gasket and seals. Then I should be good to go another 100,000kms at least.(knock on wood). Anything else I should consider getting done? Quote Link to comment Share on other sites More sharing options...
brus brother Posted December 31, 2006 Share Posted December 31, 2006 OK don't go gettin' intellectuwal with us now! Good Luk! I'm off, I have a manual to read! Quote Link to comment Share on other sites More sharing options...
1Subaru1 Posted December 31, 2006 Author Share Posted December 31, 2006 OK don't go gettin' intellectuwal with us now! Good Luk! Its speled "inteleq-wel'. Quote Link to comment Share on other sites More sharing options...
