Spence Posted December 30, 2006 Share Posted December 30, 2006 I have a 2000 Outback with a 5sp MT. It pops out of 4th when I back off on the gas. I have a line on a 1999 Impreza 5sp MT from Japan. Will it work. Is it a good idea. Link to comment Share on other sites More sharing options...
Dr. RX Posted December 30, 2006 Share Posted December 30, 2006 I have a 2000 Outback with a 5sp MT. It pops out of 4th when I back off on the gas. I have a line on a 1999 Impreza 5sp MT from Japan. Will it work. Is it a good idea.As long as the clutch is the same type (cable or hydraulic) the tranny will work. The manual trannies are pretty much the same, you do need to make sure the that final ratio is the same (i.e. both have 3.900 or 4.111). Link to comment Share on other sites More sharing options...
keltik Posted December 30, 2006 Share Posted December 30, 2006 No idea if this will help you but all of the JDM 5speed cars ive been in (about 8) have needed 3000rpm exactly for 100kph in 5th gear. Maybe that can help you figure out if the final ratios are similar. It seems this one particular ratio is very common in japanese market Subarus. Link to comment Share on other sites More sharing options...
Dr. RX Posted December 30, 2006 Share Posted December 30, 2006 No idea if this will help you but all of the JDM 5speed cars ive been in (about 8) have needed 3000rpm exactly for 100kph in 5th gear. Maybe that can help you figure out if the final ratios are similar. It seems this one particular ratio is very common in japanese market Subarus.I know that the JDM WRX trannies came in 3.900, 4.111 and 4.444 final ratios, the gearing of each gear set may be different, but it will be one of those three final ratios. I know a few of the tranny numbers, so if there is a decal on the tranny bell housing that starts with TY, let me know and I'll see if I have the info on that particular tranny. Keltik, we would need to know the tire size to come up with the gear ratio. But that would still be guessing because most 5th gears are overdrives and not a 1 to 1 with the final ratio, so we would need to know the 5th gear ratio too. Link to comment Share on other sites More sharing options...
Caboobaroo Posted December 30, 2006 Share Posted December 30, 2006 one of the fellows over on the XT6.net gave me this link for my EJ project. Has to do with the trannys and ratios, etc. http://spda-online.ca/modules/tinycontent/rewrite/tc_28.html Link to comment Share on other sites More sharing options...
keltik Posted December 30, 2006 Share Posted December 30, 2006 Silly me, completely forgot tire size in that one - and trying to figure it all out using that seems a bit hard. I guess the transmission should have some kinda marking on it, even if it doesnt match its only a new rear diff to sort things out right? Link to comment Share on other sites More sharing options...
Spence Posted December 30, 2006 Author Share Posted December 30, 2006 My manual says that the outback has a 4.111 final,so i just need to find out what the final is on the Impreza TX. I take it that there is some way to figure this out from the part number on the tramsmission? Link to comment Share on other sites More sharing options...
Spence Posted December 30, 2006 Author Share Posted December 30, 2006 I just clicked on the link from Caboobaroo and got the answer to my question. Thanks Link to comment Share on other sites More sharing options...
Dr. RX Posted December 31, 2006 Share Posted December 31, 2006 I just clicked on the link from Caboobaroo and got the answer to my question.Thanks So, did I miss something on the chart? I didn't see a JDM Impreza TX on the, did you have the tranny number? Link to comment Share on other sites More sharing options...
johnceggleston Posted December 31, 2006 Share Posted December 31, 2006 one of the fellows over on the XT6.net gave me this link for my EJ project. Has to do with the trannys and ratios, etc.http://spda-online.ca/modules/tinycontent/rewrite/tc_28.html that is a great source of informatiuon too bad they don/t have one for automatics. Link to comment Share on other sites More sharing options...
Dr. RX Posted December 31, 2006 Share Posted December 31, 2006 that is a great source of informatiuon too bad they don/t have one for automatics.One for automatics would be twice as long, it seems that there is a different automatic application for every model of Subaru sold. An auto for a Legacy Outback is different then for a Legacy GT of the same year, and those are different from an Outback Sports of the same year. True, you can interchange the trannys, but it would be a good idea to swap the TCU also. Link to comment Share on other sites More sharing options...
