J A Blazer Posted December 31, 2006 Share Posted December 31, 2006 Tomorrow I will be replacing the front rotors on my 2000 OBW. Does anyone know the specs for the bolts that you can thread through the rotor hat in order to free it from the hub? TIA Link to comment Share on other sites More sharing options...
porcupine73 Posted December 31, 2006 Share Posted December 31, 2006 I'm pretty sure it's M8. Link to comment Share on other sites More sharing options...
Schwinnbob Posted January 1, 2007 Share Posted January 1, 2007 Hello: He is right it is 8MM. I did mine a month ago and did not even come close to needing to use them. I couple hits with a rubber mallet and they were loose. That was a good thing as only one of mine had the threaded holes. Even though I bought the car with 9K I guess one was replaced at some point before I got the car. Good luck with the top bolts that hold the caliper brackets, they can be a bear! Link to comment Share on other sites More sharing options...
porcupine73 Posted January 1, 2007 Share Posted January 1, 2007 A tip I've heard that supposedly works very well on frozen on rotors is an impact hammer run between the studs. Heck Harbor Freight has one on sale for $5 now. Link to comment Share on other sites More sharing options...
