carfreak85 Posted February 23, 2007 Share Posted February 23, 2007 There are two adjusting screws on the top/bottom and sides. Just go look at it and you will see them, they are not camoflauged. Link to comment Share on other sites More sharing options...
tsutomu Posted February 24, 2007 Author Share Posted February 24, 2007 carfreak85 said: There are two adjusting screws on the top/bottom and sides. Just go look at it and you will see them, they are not camoflauged. i kinda figured it was those. oh well ill fix it tomorrow Link to comment Share on other sites More sharing options...
carfreak85 Posted February 26, 2007 Share Posted February 26, 2007 Alrighty, just got back to home base with pics of how to cut the grill for the larger, chrome 3rd eye cover. As you can see in the first picture, cut along the vertical zig-zag things. The second picture shows the angle to cut to clear the opening and closing of the cover. The best advice I can give to those doing this conversion in the future would be to TAKE YOUR TIME! Unless you have piles of spare grills, you can't go hacking them up. I would also suggest using a dremel or small (Tiny actually) recip. saw. Lastly, I would advise making a bunch of small cuts and trim the plastic away rather then large cuts. Make a small cut, test fit the grill on the car to see where it still contacts the cover and trim again. If too much plastic is removed, your grill will snap in half if anything touches it, so leave as much as you can!! Link to comment Share on other sites More sharing options...
mikeshoup Posted February 26, 2007 Share Posted February 26, 2007 Okay, I need a third eye now Or, wouldn't it be a 5th eye on a quad headlight car? Link to comment Share on other sites More sharing options...
86BRATMAN Posted February 26, 2007 Share Posted February 26, 2007 Thats gotta be one of the coolest looking 4 eye's i've seen with the cyclopse, I like the big badge better with that install Link to comment Share on other sites More sharing options...
daeron Posted February 26, 2007 Share Posted February 26, 2007 are those hella lights australian market? Link to comment Share on other sites More sharing options...
