ZRX Doug Posted May 20, 2007 Share Posted May 20, 2007 TomRhere said: Believe it, or not.... But ATF is a pretty good pre-wash hand cleaner. Gets all the really nasty stuff off fairly well, then use whatever else you like to finish the job. Me, I do the ATF, then Fast Orange, finish with some Dawn dish soap. Two + decades of life as a self-proclaimed mechanical genius (insert smiley of choice here) have taught me the the best hand cleaner is shampoo..any brand. On your head, not your hands, fool! Washing your hair gets ALL the crud out from under your nails and 'twixt the cracks of your knuckles..lather, scrub the heck outta your knucks & nails using your head for the scrub brush, rinse, repeat..anything else takes longer just to wash your mitts than it does to do the whole shower, IMHO.. Dunno what I'm gonna do if I ever go bald.. :-p Link to comment Share on other sites More sharing options...
86BRATMAN Posted May 20, 2007 Share Posted May 20, 2007 How about getting a big sheet of cardboard and laying it under the front of the car overnight. That would keep it from getting on the pavement if its not leaking real bad. Link to comment Share on other sites More sharing options...
Davalos Posted May 20, 2007 Author Share Posted May 20, 2007 dhise said: If you want, we could really freak her out and park my loyale behind yours and have two old oil leaking subaru's on her driveway! Hahaha!!! yeah! That would rock! But I gotta warn ya - she's a real pistol. she had me in a headlock last night & was beating me with her sneaker. Glas she wasn't wearing heels! 86BRATMAN said: How about getting a big sheet of cardboard and laying it under the front of the car overnight. That would keep it from getting on the pavement if its not leaking real bad. Yep - that seems like it's gonna be the best solution. Don't have much other choice, I guess. Can't use gas on the driveway beacuse it's blacktop. Link to comment Share on other sites More sharing options...
daeron Posted May 20, 2007 Share Posted May 20, 2007 are you positive its motor oil? What are the chances that it is just ATF leaking down from a faulty power steering pump? I know MY pump leaks all over the place :-\ Link to comment Share on other sites More sharing options...
Cougar Posted May 20, 2007 Share Posted May 20, 2007 Davalos said: Hahaha!!! yeah! That would rock! But I gotta warn ya - she's a real pistol. she had me in a headlock last night & was beating me with her sneaker. Glad she wasn't wearing heels! It sounds like the relationship with your landlord is getting kind of kinky. Did you like the spanking? :-p As far as the oil drip is concerned it is too bad that this is still occurring after all your good work. You did do a very nice job. Putting a drip cover down on the driveway would be the easiest thing to do. Link to comment Share on other sites More sharing options...
Gloyale Posted May 21, 2007 Share Posted May 21, 2007 Davalos said: Yep - that seems like it's gonna be the best solution. Don't have much other choice, I guess. Can't use gas on the driveway beacuse it's blacktop. Just tell her to take a look at the chemical make up of blacktop. It's mostly oil anyhow!! If the drive was brand new concrete I could somewhat understand the biatching, but Blacktop!!!! C'mon... Link to comment Share on other sites More sharing options...
dhise Posted May 21, 2007 Share Posted May 21, 2007 Gloyale said: Just tell her to take a look at the chemical make up of blacktop. It's mostly oil anyhow!! If the drive was brand new concrete I could somewhat understand the biatching, but Blacktop!!!! C'mon... Yeah, I don't understand how a blacktop driveway is a problem here. I drive my wagon to clients houses and I usually stay off the cement driveways due to the leaks. I don't want any customers freaking out in these upscale neighborhoods with any oil spots, but I have no problem parking on a blacktop driveway. It doesn't show! -Doug Link to comment Share on other sites More sharing options...
ZRX Doug Posted May 22, 2007 Share Posted May 22, 2007 The problem is oil destroys blacktop, sorta like pouring paint thinner on plastic..it makes concrete LOOK messy, but it puts craters in asphalt. Link to comment Share on other sites More sharing options...
snoboy Posted May 31, 2007 Share Posted May 31, 2007 Davalos said: So now my fingers are crossed - doesn't look like you can even GET to 25% of those bolts without lifting that motor if I have to correct a leak .... ugh! Undo engine mount bolts, jack engine up an inch or two, and use a long extension with a U-joint on it and you can get in there with some patience. Link to comment Share on other sites More sharing options...
Gloyale Posted May 31, 2007 Share Posted May 31, 2007 snoboy said: Undo engine mount bolts, jack engine up an inch or two, and use a long extension with a U-joint on it and you can get in there with some patience. Often a little snugging will help without even changing the gasket. Don;t go too tight but they are ussually about a 1/4-1/2 turn loose after 20ish years. Link to comment Share on other sites More sharing options...
