NV Zeno Posted November 17, 2003 Share Posted November 17, 2003 '83 GLW. Hitachi, Calif model: This has become more pronounced over the last couple of months. While cruising at part-throttle usually in 2nd or 3rd gear in the 2500-3000 RPM range (just going the speed limit kind of driving) the car kind of "bucks" until I let off the gas, or aggressively accelerate. No sputtering or backfiring, just enough buck to make passengers' heads look like "Bobble-heads". I thought it might be starving for air, removing the air filter lid had no effect. The O2 is last-year new, cat original. New muffler, new plugs, rotor, cap, Magnecor wires. Since this has gotten really bad, the gas mileage has gone from the high 20's(25-29 MPG) to around 22. The engine starts and idles idles beautifully, even on sub-freezing days. My guess is carb, but any other ideas are certainly welcome. Link to comment Share on other sites More sharing options...
Cougar Posted November 17, 2003 Share Posted November 17, 2003 I would check these things to try and find the problem. The fuel pump may be weak so check the fuel pressure. Check the intake system for a vacuum leak. I have had to replace the intake manifold gaskets before. Your CAT may be causing some back pressure in the exhaust system. PS- Say hello to the Cartwrights. Link to comment Share on other sites More sharing options...
