brake process?
i feel like moron having to ask for directions, but could someone point me in the right place where i could find a process for doing my front brakes and rotors on my 88 subaru wagon? i know there has to be one around here, but cant seem to find it. thanks.
Engage E-brake
Break loose axel nut.
Jack up car and place on jackstands
Remove wheel
Remove 12mm bolt at lower side of caliper.
Release E-brake
swing caliper upwards and then inwards to remove from upper pin.
Stick caliper under halfshaft.
Remove brake pads.
Undo 17mm caliper bracket bolts
Remove caliper bracket
Undo axel nut
Pull hub and rotor off of axel end
Remove 4 14mm bolts holding rotor to hub
Reverse process to assemble.
