NoahDL88 Posted January 4, 2007 Share Posted January 4, 2007 So, my camber is not able to be adjusted all the way in using the EJ camber adjusting bolt, which means my angles are screwed up, and because of that my CV's are axially compressed, so they make funny noises (not funny ha ha, but funny ) anyway. My plan is to lenthen the control arms by cutting them and extending them 25mm, or about 1 inch, to bring the hub out to where it should be happier. Does this sound stupid? I'm gonna have a real welder do this, i can weld, but i know just enough about welding to know to let a professional do it. Link to comment Share on other sites More sharing options...
86ruguy Posted January 4, 2007 Share Posted January 4, 2007 while you're at it why don't you just do some aluminum control arms?:-\ might be easier then cut and weld. just my .02:) Link to comment Share on other sites More sharing options...
ninjaben43 Posted January 4, 2007 Share Posted January 4, 2007 do you think your cv's will allow for that inch?, how much is it lifted, mine has never effected the front cv's with a aa 4 in. lift, yeah it looks a little funny, but the geometry is no different. by doing this you may run into probs....just a thought. Link to comment Share on other sites More sharing options...
NoahDL88 Posted January 4, 2007 Author Share Posted January 4, 2007 At this point the car is not driveable, so i'm willing to take my chances. Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted January 4, 2007 Share Posted January 4, 2007 Noah some questions what car model what transaxle what axles what struts what lift how high what knuckles Link to comment Share on other sites More sharing options...
NoahDL88 Posted January 4, 2007 Author Share Posted January 4, 2007 1988 DL Wagon 88 GL Dual range Impreza FWD Axles 98 OBS Struts PK 3" lift Impreza Knuckles Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted January 4, 2007 Share Posted January 4, 2007 are Impreza axles longer then EA82 axles ? which way is your camber goofed up, looking at the front, \.... / or /.... \ Link to comment Share on other sites More sharing options...
baccaruda Posted January 4, 2007 Share Posted January 4, 2007 weird.. my camber's normal although I had a hell of a time with the control arm bolts (did them last) I have: 1986 GL10 Wagon 88 RX FT4WD Dual range Legacy FWD Axles / knuckles '92 Legacy Struts - KYB GR2s (maybe 1993, whatever year has the spring perches sit an inch higher) / WRX springs PK 4" lift If it matters I have the round motor mounts on my EJ and the transmission mounts and strut rod bushings are brand new. Link to comment Share on other sites More sharing options...
NoahDL88 Posted January 4, 2007 Author Share Posted January 4, 2007 I'm \....../ from the front, and if you're looking at it from the top, its the same, i've got about a half and inch toe in. Link to comment Share on other sites More sharing options...
monstaru Posted January 5, 2007 Share Posted January 5, 2007 did you let it down on the ground?is it still just the drivers side? Link to comment Share on other sites More sharing options...
Subarutex Posted January 5, 2007 Share Posted January 5, 2007 Uhhh... I know this is stupid, but read this story. So, for some reason Me and Dan were led to believe we had some brand new GR-2's for mid 90's legacy. Probally OBS. We tried them on Dan's wagon, and couldn't get it together... the strut was too long. Dan sold them to Ken, and he tried to put them on the front of his XT6 rally car. DIdn't fit, was just a bit too tall. A month later, after a significant amount of sluething, Ken calls me and tells me they were REAR struts. I remember you picked up all 4 struts from the guy... make sure you have the shorter of them on the car. The control arms are xt6 correct? Didn't I give you knew radius rod bushings? Are those on? Oh... and are the strut lift blocks back on the right orientation? Link to comment Share on other sites More sharing options...
NoahDL88 Posted January 5, 2007 Author Share Posted January 5, 2007 Blocks are right They are front struts, rears don't work, they hit the axle No, you didn't give me bushings :-\ Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted January 8, 2007 Share Posted January 8, 2007 ........................Buy a Jeep ........................... HHHHHaaaaaaaaaaaaaaaaaa :banana: Link to comment Share on other sites More sharing options...
soobmater Posted January 9, 2007 Share Posted January 9, 2007 Scott in Bellingham said: ........................Buy a Jeep ........................... HHHHHaaaaaaaaaaaaaaaaaa :banana: Scott, your not my friend anymore:lol: Link to comment Share on other sites More sharing options...
s'ko Posted March 11, 2007 Share Posted March 11, 2007 NoahDL88 said: I'm \....../ from the front, and if you're looking at it from the top, its the same, i've got about a half and inch toe in. Noah did you ever ger this issue resolved? I have the same problem. \--/ front wheel. BRAT EJ18, XT6 hubs, Outback struts custom 5 in lift Impreza RWD axles When I made the blocks I off-set the strut mounts. The struts were a PITA in get mounted to the hubs. I was thinking of adding about and inch to the control arm. Let me know what you have done. BW Link to comment Share on other sites More sharing options...
baccaruda Posted March 11, 2007 Share Posted March 11, 2007 my wagon's front tires look fine.... I used new GR2s for 92 Legacy .. I'm a little fuzzy on the year but they're the GR2s that have the highest spring perch position.. My control arms are the same length as everyone else's! it's got to be the struts. Link to comment Share on other sites More sharing options...
Subarutex Posted March 12, 2007 Share Posted March 12, 2007 Noah has custom arms in the works... Should be done soon. I'm in agreement with the struts being the culprit. Link to comment Share on other sites More sharing options...
monstaru Posted March 12, 2007 Share Posted March 12, 2007 good to hear about the control arms.can't wait to see'em:grin: Subarutex said: Noah has custom arms in the works... Should be done soon. I'm in agreement with the struts being the culprit. Link to comment Share on other sites More sharing options...
