Anybody ever cut this thing off?
When changing my axles in my 90 Loyale I had a clearance problem with a piece of sheet metal. It's a piece of the body metal that comes down from the inside of the fender in a triangle shape and has a hole in it that the brake line runs through. I bent it up and out of the way to make room for the boot as the axle came out and back in. Does anybody know why that's there? It doesn't seem to do any real purpose. Has anybody ever hacksawed it off? It would make future axle jobs a whole lot easier IMHO.
  Sweet82 said:
Which side of the car is this on?
Sounds like it might be a heat shield?
If it is...you probably don't want to
remove it.
It's not a heat sheild. It's on both sides. I'll have to post some pics, but it is a piece of the body and runs down vertically allong the outside edge of the fender/subframe and extends past the bottom of the fender/subframe.
That is just a mud guard. If you put the axle in from the front of the strut it isn't in the way and insert the asle from the outside in to the tranny. I've done many axles and it has never been an issue. You just have to work around it. It won't hurt if you cut it off though.
