LSD units- interchangability?
RacerAl
Does anybody know if the viscous and clutch pack LSD units are interchangeable?
Do you know what car they came out of, R160 parts does swap with R180 parts. It would be good to have some more info on what you are thinking of swapping.
Meeky Moose has a VLSD in his EA81 wagon. I guess the early legacy 3.9 VLSD units are the ones that work.
Yes, a VLSD out of a 91 Leg Turbo will work, they are the same series rear diff, R180s I believe. The difference is that the Leg diff has stub axles held in by a 'C' clip and the others are held in by a bolt, so the inners will change, but you'll need the correct stub axles too.
