Joey Joe Posted January 8, 2007 Share Posted January 8, 2007 I am diving into a head gasket replacement..... coolant leaving the system, over heating, oil and water are mixing in both systems and I have bubbles coming out the coolant over flow tank, and water in the oil, Oh yeah this engine has less than 70k original miles, so I have cold feet about this head gasket diagnosis. When I pulled the turbo to intake section off there was tons of milky coolant water around the edges(meaning coolant is going right into the intake through the turbo?). It may be a side effect of the blown head gasket (since the turbo runs off exhaust) but I do not know how the turbo relates to the engine, it seems weird that their would be a lot of dirty coolant and water in the turbo to intake pipe. I have not had this sympyom before, and I have done a head gasket. I am wondering if this could be an internal turbo problem, and not a head gasket????? My question is, is it normal for coolant and oil to be in the turbo to intake section when their is a head gasket blown, or does this maybe sugest that the turbo is f'ed. Link to comment Share on other sites More sharing options...
idosubaru Posted January 8, 2007 Share Posted January 8, 2007 this is on the loyale turbo in your profile or something else? being a later model turbo i think you have coolant and oil lines going to your turbo, they could be mixing there at the turbo. i'm not very familiar with turbo's, but they can blow seals and leak oil and coolant and i'm guessing it could mix? sounds like headgaskets though, have you tried a compression test? Link to comment Share on other sites More sharing options...
Joey Joe Posted January 8, 2007 Author Share Posted January 8, 2007 I have not, so maybe I should....................................I was just going to tear into it, but now I think I will compression test it. Link to comment Share on other sites More sharing options...
Turbone Posted January 9, 2007 Share Posted January 9, 2007 You have the worst case scenario for a blown HG. I would have the heads decked a little too, I would bet they are a tad warped. Link to comment Share on other sites More sharing options...
beataru Posted January 9, 2007 Share Posted January 9, 2007 You have the worst case scenario for a blown HG. I would have the heads decked a little too, I would bet they are a tad warped. yeah definately have the heads decked.... and check for blemishes in the combustion chamber... or your mechanic, who is performing the repair??? Link to comment Share on other sites More sharing options...
jeffast Posted January 9, 2007 Share Posted January 9, 2007 don't drive it like that at all it is 99.9 percent chance it's a head gasket deck the heads and get oem or felpro gaskets and spend a weekend on it, jeff has spoken Link to comment Share on other sites More sharing options...
