4x4moose Posted January 10, 2007 Share Posted January 10, 2007 so i got the crank pulley off. but ran in to a bigger problem. if i had a picture it would help me explain it all. i have part of my oil pump broke off in my block and not sure how to go about removing it. 1. i don't want to mess up the mateing serface on the block. 2. i don't have a whole lot of tools to work with right now. a hammer and chisel is about it. so any ea-81 masters around tonight? Quote Link to comment Share on other sites More sharing options...
DaveT Posted January 10, 2007 Share Posted January 10, 2007 i have part of my oil pump broke off in my block and not sure how to go about removing it. Been a long time since I touched anything older than an EA82... A rough / starter idea: Drill & tap into some part of the broken piece, or catch a bolt head on the edge of a passageway in the stuck piece. Use a pry bar against a nut on the bolt. You may need 2 or 3 locations to work it out. It must come straight out or it will bind. Turning the piece might help. I remember some of them being looser & tighter at different angles. Quote Link to comment Share on other sites More sharing options...
4x4moose Posted January 10, 2007 Author Share Posted January 10, 2007 were it is in red and then some of the flat area. i would be easer to explain it to someone that knows ea-81. i have now drill or tap, that would work if i had them. oilpump.bmp Quote Link to comment Share on other sites More sharing options...
baccaruda Posted January 10, 2007 Share Posted January 10, 2007 is this broken off as if the oil pump had been glued onto the front of engine? or is it broken off inside of the bore for the round section of the pump? Quote Link to comment Share on other sites More sharing options...
4x4moose Posted January 10, 2007 Author Share Posted January 10, 2007 is this broken off as if the oil pump had been glued onto the front of engine? or is it broken off inside of the bore for the round section of the pump? yeah the round section is broke off from the rest of the pump. give me a sec and i will get some real pics up, i forgot about the roommate's cam:lol:. i guess you could say it was almost as if someone glued it to the block. pic 1(left) is whats stuck in the block. 2(right) i whats came off the motor. Quote Link to comment Share on other sites More sharing options...
baccaruda Posted January 10, 2007 Share Posted January 10, 2007 OK, the parts that are outside the surface of the bore, are they adhered to the block or are they part of the broken-off part inside? Quote Link to comment Share on other sites More sharing options...
mcbrat Posted January 10, 2007 Share Posted January 10, 2007 I had the exact same thing happen to me on a high mileage 85 hatch.... easier ifengine is out of vehicle or at least lifted. mine was stock. I basically used a big ol' screwdriver and pried and prodded on the busted off piece, continuously removing all the pieces that came off as I worked it back and forth. what's left in the block should be able to spin inside the bore, so it's just a lot of time and patience of trying to pry it out a bit and trying to spin it. I bet I worked 3-4 hours on it. came out cleanly, and put a new pump in no problem. you do have to be careful of the outer machines surface, but it's defintely do-able. re-looking at your pics, you at least have part of the piece outside the hole, so you should be able to tap on that piece to get it to spin... Quote Link to comment Share on other sites More sharing options...
4x4moose Posted January 10, 2007 Author Share Posted January 10, 2007 mcbrat, that what i'm going to do. i already broke a piece, and now a whole lot more has to come off, only if i had a big hammer and a sharper chisel. i think the peice inside the bore does spine the tinnest amount. now i get to stay up late and get up at 5am. is the metal the oil pump is made of softer then the block? Quote Link to comment Share on other sites More sharing options...
4x4moose Posted January 10, 2007 Author Share Posted January 10, 2007 damn that was to easy. i started beating on it and it came out. so happy, i thought that i was screwed. thanks everyone for your help! Quote Link to comment Share on other sites More sharing options...
baccaruda Posted January 10, 2007 Share Posted January 10, 2007 hey, with that particular problem you were right to ask first and pound on it later! good job. Quote Link to comment Share on other sites More sharing options...
Turbone Posted January 10, 2007 Share Posted January 10, 2007 Amazing:cool: Quote Link to comment Share on other sites More sharing options...
