murphsubaru Posted January 12, 2007 Share Posted January 12, 2007 I have a 99 Forester with abs that is not working. Local garage checked for codes and found nothing wrong. ABS light does not come on when the ignition is turned on, I believe this indicates a problem. Any solutions would be aprecieated. Link to comment Share on other sites More sharing options...
nipper Posted January 12, 2007 Share Posted January 12, 2007 Have you checked to see if the bulb is working. The bulb circuit is from the ABS controller. Have they checked to make sure its getting power. It can be as simple as one of the power relays are burned out. email me before 9am tomorrow at nipper.dawg@gmail .com and ill mail you a witrining diagram for a subaru that will give you an idea how its set up. nipper Link to comment Share on other sites More sharing options...
