El Toro Posted January 24, 2007 Share Posted January 24, 2007 when you get back to kitsap you will have to meet up w/ some of us at tahuya Link to comment Share on other sites More sharing options...
thatswhatshesaid Posted January 24, 2007 Share Posted January 24, 2007 If you ever sell that thing, let me know...(especially if you want to do it on your way back to western WA...I'm right on the way if you take the Post Falls route...) Link to comment Share on other sites More sharing options...
Rooinater Posted January 25, 2007 Author Share Posted January 25, 2007 i'll be 30 minutes from tahyua, i'll actually be living in wauna on the way up to tahuya, i'll be there riding my quad all the time. it's about 45 minutes to evans creek also... Link to comment Share on other sites More sharing options...
heep70 Posted January 25, 2007 Share Posted January 25, 2007 Going to Evans the weekend after this one :-p Ha ha ha:grin: Link to comment Share on other sites More sharing options...
Rooinater Posted January 25, 2007 Author Share Posted January 25, 2007 thanks for rubbing it in!... 5 months and 11 days! well first weekend of feb. i'm gonna go play in the 8 ball mine and laguna mountain washes! :-p:headbang: i'll have to get some real pics of lil' roo on the trail since all the mods... it only took me 3 years to get around to getting pictures... lack of digi camera and neglected vehicle... now i got a phone and an slr digi camera, which i'm selling... Link to comment Share on other sites More sharing options...
Rooinater Posted January 25, 2007 Author Share Posted January 25, 2007 tie rod's in. now i need to play with them to make it so it doesn't jerk slightly right when i let go of the gas. maybe the right one needs replacing too... did a little investigation on the rearend... it feels like i might of just broke a stubby off in the diff... and if it's in there good enough, it is not going to be fun to remove... i jacked the rear and can jiggle and pull the axle cup away from the diff slightly. the other side that still turns the drive shaft doesn't pull out... maybe my welds held :-\ hooked up the rear driveline again and it started making the noise in the tcase. so out goes the tcase for sure. and try to find my tool to unbolt a stubby and swap one out with my spare diff. tomorrow! then to the steel yards to find a chunk of 1/4" plate to make a skid for the tcase. 8 ball mine's trails this saturday if i'm lucky! almost forgot, this week i need to make vent lines for the diffs and bring the front into the engine compartment and the rear into the cab. Link to comment Share on other sites More sharing options...
chazmataz Posted January 26, 2007 Share Posted January 26, 2007 Rooinater said: thanks for rubbing it in!... 5 months and 11 days! well first weekend of feb. i'm gonna go play in the 8 ball mine and laguna mountain washes! :-p:headbang: i'll have to get some real pics of lil' roo on the trail since all the mods... it only took me 3 years to get around to getting pictures... lack of digi camera and neglected vehicle... now i got a phone and an slr digi camera, which i'm selling... yeah make sure and get some pics. Rooinater said: it feels like i might of just broke a stubby off in the diff... and if it's in there good enough, it is not going to be fun to remove... my last one i broke wouldn't come out so i took a tap and tapped out the center and ran a bolt with a washer on it into the center hole and used a prybar prying under the washer against the side of the housing and it just popped out. i tried everything else short of pulling out the diff and taking it apart. i don't remember what size off hand, i think it was 7/16 but i can let you know, i'll check when i get to work tomorrow and i can let you know if you want. unless you have already done this before i had also entertain the idea of using a dent puller but was told it was to small but i did have one other option i was thinking of before i had this idea. Link to comment Share on other sites More sharing options...
Rooinater Posted January 26, 2007 Author Share Posted January 26, 2007 i've had to do it in a lsd a few times. problem is this ones welded tight and access from the other side is slim. i'll look more into it tomorrow when i have it off. if i can even unbolt it... don't remember how thourough i was with welding it... Link to comment Share on other sites More sharing options...
chazmataz Posted January 26, 2007 Share Posted January 26, 2007 Rooinater said: i've had to do it in a lsd a few times. problem is this ones welded tight and access from the other side is slim. i'll look more into it tomorrow when i have it off. if i can even unbolt it... don't remember how thourough i was with welding it... OOPS that might suck. well good luck. hope everything works out for ya on fixing it, would really like to see some pics of it in the wild since its been sitting awhile. Link to comment Share on other sites More sharing options...
Rooinater Posted January 29, 2007 Author Share Posted January 29, 2007 well the broken stubby came out easy. and went right back in! swapped out the tcase and didn't seem to fix the problem all the way... so i'm going to do some more putting around and seeing what else i can do... got a wobble in the front right tire and a driveline vibration... then i broke the other stubby... so i'll be collecting more... going to investigate the front right wobble and change some u joints out on the rear driveline. Link to comment Share on other sites More sharing options...
