The condensate drain for my A/C is plugged, and in the summer, every time I make a sharp turn, the water overflows and spills into the passenger or driver's footwell.
Where is the drain tube and what is the best way to access it/clean it?
What Nipper said with one addition---it's down low on passenger-side of firewall--it's a rubber hose that sticks thru the firewall and the end of the hose is "closed off" to prevent stuff from going backwards thru it. Only problem with that design is that the slightest amount of dirt will restrict the hose where it closes off and it becomes plugged.
