NoahDL88 Posted January 17, 2007 Share Posted January 17, 2007 Will the bushings and inner metal tubes from the XT-6 fit on RX control arms? cause i have the XT-6 bits on my car, but if i take them off to lengthen them its conna be immobile, so if i can swap the inner bushings i won't have to take them off the car. Also, i know i'll have to drill the outer ball joint hole, anyone know specifically how big, or do you just go one size bigger from the size it is until you get a good fit? Quote Link to comment Share on other sites More sharing options...
joostvdw Posted January 18, 2007 Share Posted January 18, 2007 Will the bushings and inner metal tubes from the XT-6 fit on RX control arms? cause i have the XT-6 bits on my car, but if i take them off to lengthen them its conna be immobile, so if i can swap the inner bushings i won't have to take them off the car. Also, i know i'll have to drill the outer ball joint hole, anyone know specifically how big, or do you just go one size bigger from the size it is until you get a good fit? how about measuring the new ball joint and THEN drilling the control arm to the correct size? you don't want to screw this up because it is sort of important Quote Link to comment Share on other sites More sharing options...
baccaruda Posted January 18, 2007 Share Posted January 18, 2007 be careful that the hole doesn't have a taper.... Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted January 18, 2007 Author Share Posted January 18, 2007 be careful that the hole doesn't have a taper.... It does, but i'm positive someone has drilled out that hole before. :cool: Quote Link to comment Share on other sites More sharing options...
TomRhere Posted January 19, 2007 Share Posted January 19, 2007 It does, but i'm positive someone has drilled out that hole before. :cool: Miles Fox has, using various sizes of drill bits to "step taper" the hole. One can get a tapered ream to open the hole up, not sure on cost though, could be pricey. Quote Link to comment Share on other sites More sharing options...
