junkyardgabe Posted January 18, 2007 Share Posted January 18, 2007 will an ea81 wagon wheel fit over and ea82 rear disc brakes set-up with no mods? Link to comment Share on other sites More sharing options...
ratfink Posted January 18, 2007 Share Posted January 18, 2007 will an ea81 wagon wheel fit over and ea82 rear disc brakes set-up with no mods? http://www.ultimatesubaru.org/forum/showthread.php?t=49966 this is speculation, but i assume they'll fit, since the post doesn't mention it, and the rear brakes should be smaller than the front. Link to comment Share on other sites More sharing options...
Numbchux Posted January 18, 2007 Share Posted January 18, 2007 they will clear in the rear, but will most likely rub on the front calipers. Link to comment Share on other sites More sharing options...
[HTi]Savage Posted January 18, 2007 Share Posted January 18, 2007 Yes. They will most likley rub in the front. I am using a set of 8 spokes on my Rx. If the front brakes are at 50% or less they will clear. There are 2 different types of 8 spokes. there is an older version that have more of an offset. I think on older EA81,s. If ur using 8 spokes. Link to comment Share on other sites More sharing options...
GoldDiggerRoo Posted January 18, 2007 Share Posted January 18, 2007 Not sure about the rear discs but they do hit significantly on the front calipers, I had a set on my forst EA82 wagon and I had to do quite a bit of grinding on the calipers to get them to fit. There are however EA82 wagon wheels out there, which require no grinding. Their spokes come out further before turning inward, thus clearing the calipers. I have a set on my hatch, which I'd gladly trade for EA81's. Bad pic, but you can tell the difference between them and the EA81's Link to comment Share on other sites More sharing options...
junkyardgabe Posted January 19, 2007 Author Share Posted January 19, 2007 these are for my brat which i have done the ea82 rear disc too. so i'm not worried about the fronts i know they'll clear. thanks for your help Link to comment Share on other sites More sharing options...
Numbchux Posted January 19, 2007 Share Posted January 19, 2007 these are for my brat which i have done the ea82 rear disc too.so i'm not worried about the fronts i know they'll clear. thanks for your help aha, sorry, then they'll fit. the rear discs have plenty of clearance. Link to comment Share on other sites More sharing options...
