carfreak85 Posted January 21, 2007 Share Posted January 21, 2007 Has anyone done this to their EA81s or have pictures of it? I'm mostly interested in pics and what people did to fill in the holes in the doors? Quote Link to comment Share on other sites More sharing options...
RdNkBrt Posted January 21, 2007 Share Posted January 21, 2007 bondo Quote Link to comment Share on other sites More sharing options...
75subie Posted January 21, 2007 Share Posted January 21, 2007 yes bondo or a stripe kit Quote Link to comment Share on other sites More sharing options...
Bucky92 Posted January 21, 2007 Share Posted January 21, 2007 Duct Tape;) J/K Bondo Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted January 21, 2007 Share Posted January 21, 2007 do it right or it'll fall out. Weld the hole , grind it down and use some bondo... Quote Link to comment Share on other sites More sharing options...
Frank B Posted January 21, 2007 Share Posted January 21, 2007 If you can get to the back side of the metal, you can tack weld some sheet metal pieces to cover the hole, then bondo on the outside. Or I guess you can use JB Weld to keep the sheet metal in place too. Just 1 or 2 inch squares of metal. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 21, 2007 Share Posted January 21, 2007 Weld, then knock down slightly with a hammer so there's a shallow dimple. You don't want bondo exposed on the inside, and you don't want the bondo very thick - as thin as possible. Thus the welded hole, and a shallow dimple to fill. GD Quote Link to comment Share on other sites More sharing options...
RdNkBrt Posted January 21, 2007 Share Posted January 21, 2007 if you cant weld it, you could always creat a dent and then use a patch kit over the dent and then bondo over that. that way the bondo is not exposed on the other side. Quote Link to comment Share on other sites More sharing options...
SOOBOUTLAW Posted January 21, 2007 Share Posted January 21, 2007 Hehe, the ol Bondo the hole thing. The bondo can usually comes with screens to use as a backing behind the hole, that's what I did. But only on one door I replaced on the wagon. High build primer and a sanding block will make it smooth as a Standard door. BTW, is there such thing as a Standard Wagon? Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted January 22, 2007 Author Share Posted January 22, 2007 I was planning on welding the holes. Has anyone done this to their cars and have pics? To answer your wagon question, there were never standard wagons ever produced by the factory. Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted January 23, 2007 Share Posted January 23, 2007 I have a set of gen 1 fenders that I shaved the trim on and was planning on doing it to my old '78 Brat. Never got around to finishing it though. The fenders look awesome, even though I also shaved the side marker lights that were in them:grin: Quote Link to comment Share on other sites More sharing options...
