desertsubaru Posted January 21, 2007 Share Posted January 21, 2007 About a year ago someone posted a link for a parts place that Has the adjustable struts for an 86 wagon. I did a search but cant find the post and cant remember the name of the place. Does anyone have it please. I should have bought the ones i looked at but just couldnt afford it. Now income tax are on there way so its time to find them again. Oh and I want the mechanical adjustable ones not the air. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 21, 2007 Share Posted January 21, 2007 Front or rear - just to clarify: Front's are struts, rear's are coil-over shocks. Struts have the ability to turn via the strut "top" which has a bearing inside it. Coil-over's do not. GD Link to comment Share on other sites More sharing options...
desertsubaru Posted January 21, 2007 Author Share Posted January 21, 2007 Front or rear - just to clarify: Front's are struts, rear's are coil-over shocks. Struts have the ability to turn via the strut "top" which has a bearing inside it. Coil-over's do not. GD Im looking for all four GD, you know the ones with the two adjusting bolts on the front struts and the rear coil over adjustable. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 21, 2007 Share Posted January 21, 2007 If you can find them, I beleive the Monroe sets are adjustable. At least the front's are. I've seen them on ebay periodically. Also it's possible to put new cartridges into existing struts that are already adjustable. But you may have to hunt around for the right size cartridge, and it will require some welding and cutting most likely. GD Link to comment Share on other sites More sharing options...
