Forester engine replacement
Sorry if this has already been posted. I'm having some computer issues.
We are getting ready to replace the engine in our 99 Forester. I went ahead and purchased the Subaru service manual from ebay and was thinking about grabbing a Chilton's but have heard pretty negative things about them on this board for the Subarus. I am pretty confident in my mechanic's skills but it is always nice to have as much information and advice as I can get.
Does anyone have any big warnings or suggestions on what to do or not to do before we get started.
Thanks.
the subaru FSM and this board would be your best resource for doing the job. take the FSM with you to a parts store and compare it to a Haynes manual and see if it really offers you any crucial information, i think you'll find the FSM's all you need. if you decide on an aftermarket set, like nipper said, Haynes is the way to go over Chilton's.
Out of curisoty, what are you replacing the engine?
nipper
Not sure if you meant why or what. But I posted earlier about our engine seizing due to lack of oil plug. We wanted to go with the EJ22 motor but according to Emily at CCR starting with the 99 Forester we cannot do that. So we ended up buying an EJ25 at the local wrecker.
A friend of mine also suggested the library. Unfortunately we have only one car now and my husband can't use it to take care of some of these things as he is a parapalegic and our truck is manual. So I will have to try to do on my lunch hour or after I pick up the engine today.
Anybody have any idea how heavy these engines are. I have a Toyota pickup that theoretically should be at leat a half ton so I'm hoping i won't have any problems transporting.
you won't have any problem hauling an engine in the back of your toyota pick up. i've hauled engines, transmissions in the back of my 2 door XT6 coupe, they fit in the trunk even. with one i can even close the trunk, with two i can't if they're full engine assemblies. an engine, while heavy isn't that heavy that any typical road vehicle wouldnt' be able to handle it.
Shipping weight on my 2.5 DOHC was 215 lbs. That includes the pallet. My wife and I picked it up and placed it on a furniture dolly. Your 'yota will have no trouble with it.
