headlight swap 82 to 84
mtnman38
OK so Im going from a two square to 4 square I have all of the work done I just can not get the lights to turn on
I switched the wires and plugs in the engine compartment form the harness
is there a seperat relay for 4 light or is there somthing else I need to change
ant in put would be grand
thanks
On a serious note.
With the key in the run position and the head light switch in the OFF position.
Connect a test light to ground and then check for juice on the main
harness connection. (unplug the headlights - both sides)
One terminal on the left and one on the right should have juice if not check fuses 9 and 10 (as per 84 FSM)
This is the common terminal for the lights.
The element(s) you want to illuminate (high or low) is (are) provided a ground
by the hi/lo stalk when the headlight switch is on.
Hope this helps.
There is no other relay involved in the illumination (the sub fan control is involved but
does not affect the lighting of said lamps).
yea well when I started this project I did a little research to see if there was any thing to watch for no one else has had this problem
I cheched all of the fuses first thing when it did not work
the vehicle had some severe problems so Im begining to think that the lights did not work before I started this
I am going to go out and see if I can figure it out after breakfast
ill keep ya posted
ok so i pulled the fuse panel and the fuses 9-10 had three wires attached but no power so I jumed power from an empty fuse location now I have lights but the brights wont work buy them selves but will work if you just flash them I ran out of tme but will try to figure the rest out tomarrow
thanks for your help
