Guest Subie8 Posted January 23, 2007 Share Posted January 23, 2007 is it possible to fit and run a ez30 engine out of a 97 Outback in a 90-94 Legacy? Quote Link to comment Share on other sites More sharing options...
Ratty2Austin Posted January 23, 2007 Share Posted January 23, 2007 anything is possible.... it depends on how much $$ and time you are able to put into the project.. bolting up that engine should not be a problem- it will fit into that body of car, but the problem will be getting all the wiring to work, as the EZ30 is OBDII or that new networking stuff? much more advanced than the EG33, which is a much larger engine... but yes, it can be done. Quote Link to comment Share on other sites More sharing options...
Skip Posted January 23, 2007 Share Posted January 23, 2007 EZ30 in a 97 OB?? Subaru 6 cyl history Quote Link to comment Share on other sites More sharing options...
Numbchux Posted January 23, 2007 Share Posted January 23, 2007 like austin said, definately would work mechanically, but the wiring would be quite in-depth. also, IIRC the EZ30 (might just be the EZ30R) has 2 coolant outputs on the top of the engine, and one input on the bottom, so you'd have to use the radiator to match the engine. the EZ30R is virtually impossible to run in anything but it's factory configuration on a stock ECU. the hydra is possible, but pretty difficult. but an EZ30 would be similar to doing a WRX swap. I have some EZ30 plans myself, actually Quote Link to comment Share on other sites More sharing options...
Skip Posted January 23, 2007 Share Posted January 23, 2007 I would like to see this 97 OB with the EZ engine. Please post a photo or a link to it. If someone put it in an OB the same would go for a Legacy as Chux says it would be a chore but only being 2 cm longer (less than an inch) than an EJ, the fit would not be the problem. The tranny bolt up and wiring well... they went to 8 bolt bellhousing but not in 97. The varriable intake and other bits.. good luck may the power of the Pleiades be with you. show me this 97 EZ30 OB first please Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted January 24, 2007 Share Posted January 24, 2007 show me this 97 EZ30 OB first please i would like to see it as well, if it is in there it is not stock, the 3.0HO wasn't an option untill the 00-04 legacy Quote Link to comment Share on other sites More sharing options...
kiwi subbie Posted January 24, 2007 Share Posted January 24, 2007 i like to fit ez30 in to something too for project Quote Link to comment Share on other sites More sharing options...
kiwi subbie Posted January 24, 2007 Share Posted January 24, 2007 The first six-cylinder engine manufactured by Subaru appeared in the 1989 model year thats wrong its 87 Quote Link to comment Share on other sites More sharing options...
Huck369 Posted February 3, 2007 Share Posted February 3, 2007 thats wrong its 87 Actually, 88 here in the US, in the 88 XT6 Quote Link to comment Share on other sites More sharing options...
WoodsWagon Posted February 4, 2007 Share Posted February 4, 2007 Need to know if the EZ30 8 bolt bellhousing would bolt up to the EJ 4 bolt tranny bellhousing. Also need to know if the EJ flywheel will bolt to the EZ crank to use an EJ clutch. Quote Link to comment Share on other sites More sharing options...
Numbchux Posted February 4, 2007 Share Posted February 4, 2007 Need to know if the EZ30 8 bolt bellhousing would bolt up to the EJ 4 bolt tranny bellhousing. Also need to know if the EJ flywheel will bolt to the EZ crank to use an EJ clutch. I would assume so on both accounts. there have been a number of people that bolt them to the STi 6MT. and since that's interchangeable with the 5MT.... Quote Link to comment Share on other sites More sharing options...
970subaru Posted February 5, 2007 Share Posted February 5, 2007 yes they bolt up. it would be an amazing swap, I would love to see it done. the ez30 is one of the coolest 6 bangers out there. but it will take LOTS of money, time, and skill. Quote Link to comment Share on other sites More sharing options...
Huck369 Posted February 5, 2007 Share Posted February 5, 2007 Yeah the 8 bolt bell housing will bolt up to the 4 bolt EJ stuff.... Here is a link to a guy that put a EZ into his Rally Impreza Coupe. http://www.linaracing.com/impreza-h6-conversion-faq.php The biggest down side to using a EZ30 for me is the cost, as they bring big money from the wreckers.... I had originally planned on using the EZ30 in FrankenWedge, but went with the EG33 due to the availability and price. Quote Link to comment Share on other sites More sharing options...
kiwi subbie Posted February 6, 2007 Share Posted February 6, 2007 wish they had pics of it working, cant veiw any coz they redoing parts of the site Quote Link to comment Share on other sites More sharing options...
