steamin53 Posted January 25, 2007 Share Posted January 25, 2007 Still trying to decide whether to buy this car. 99 outback with 43,000 miles on it. The engine seems to idle ok but just off idle from about 1000 to 1500 rpm it runs rough as heck...even shakes the body. Runs strong on the highway and seems to run smooth in neutral above 2000 rpm. Any ideas? Link to comment Share on other sites More sharing options...
porcupine73 Posted January 25, 2007 Share Posted January 25, 2007 Dirty MAF or plugs/wires maybe? This 2.5L may be one of the potential head gasket issue ones so be aware of that going in. Link to comment Share on other sites More sharing options...
steamin53 Posted January 25, 2007 Author Share Posted January 25, 2007 Since I don't own it yet... I'm not going to mess with it. Wondering about the possibilities though. From Car Fax report it appears this vehicle may have set for some time. Would you expect plugs or wires with only 43K miles on the car? Also, if it were the MAF sensor wouldn't it affect the engine at all speeds and loads. This car has good power but misses at very light throttle in gear or as I said between 1K and 2K RPM out of gear. I don't want to get burned on this one. I'm well prepared now for the head gasket possibilities. Any other ideas? Link to comment Share on other sites More sharing options...
porcupine73 Posted January 25, 2007 Share Posted January 25, 2007 Would you expect plugs or wires with only 43K miles on the car?Yes, unless it has the dohc the plug change interval is 30k or 30 months.Also, if it were the MAF sensor wouldn't it affect the engine at all speeds and loads.I'm not sure as I haven't experienced this issue. It seems I remember some similiar issues in other posts having something to do with the MAF. The knock sensor sometimes has a tendancy to crack or go weird with age on these things though I don't know it would cause what you're experiencing. Engine coolant temp sensor is another thing seen frequently but that usually causes hard starting. Link to comment Share on other sites More sharing options...
nipper Posted January 25, 2007 Share Posted January 25, 2007 Can be as simple as a dirty throttle plate. Spark plug and wires are 3/36 but realistically as long as the car is running fine you go 100K with them Since this car is running rough i would suggest a tuneup (which is the norm when you buy a used car anyway). nipper Link to comment Share on other sites More sharing options...
Aspen Posted January 25, 2007 Share Posted January 25, 2007 The OEM plug wires are not the greatest. Age will kill them as much or more than mileage, I would bet on them. ***Beware the HG failure.*** Link to comment Share on other sites More sharing options...
