Andyjo Posted January 26, 2007 Share Posted January 26, 2007 Anyone every have a problem with an LSD clicking on heavy acceleration in the cold? i seem to be having this problem... nothing major, just have to let the diffs warm up a little more i guess. Anyone know a fix? Link to comment Share on other sites More sharing options...
nipper Posted January 26, 2007 Share Posted January 26, 2007 Well lets do the obvious, check the lubricant. Clicking? check the driveshafts and the axles. Did you break your new car already? nipper Link to comment Share on other sites More sharing options...
subeman90 Posted January 26, 2007 Share Posted January 26, 2007 my rear LSD clicks when I put it into reverse and back into a parking spot. Do you hear a clunk clunk clunk when you take off from a redlight going straight etc.? Does it sound like a bad axle but quieter? My baja is making a strange noise like that. Link to comment Share on other sites More sharing options...
svxpert Posted January 26, 2007 Share Posted January 26, 2007 <<Anyone every have a problem with an LSD clicking on heavy acceleration in the cold? i seem to be having this problem... nothing major, just have to let the diffs warm up a little more i guess. Anyone know a fix?>> i think it would be the driveshaft not the diff. Link to comment Share on other sites More sharing options...
BruceyWV Posted January 26, 2007 Share Posted January 26, 2007 Hard accelleration when its cold is a bad idea anyway Link to comment Share on other sites More sharing options...
98obster Posted January 26, 2007 Share Posted January 26, 2007 Well lets do the obvious, check the lubricant. Clicking? check the driveshafts and the axles. Did you break your new car already? nipper replace the lube with synthetic-tolerates cold better? Link to comment Share on other sites More sharing options...
weddes05 Posted January 26, 2007 Share Posted January 26, 2007 Check to make sure the axle c clip is fully engaged into the diff. We had an RS in that a local well known trans shop....not mentioning any names...miss-diagnosed first as a clutch, then a trans. they sent it to us and it just turned out to be the clip in the rear axle was allowing the inner to slide in and out. you would launch the car hard and it would click a couple times and then acted like neutral. Link to comment Share on other sites More sharing options...
Andyjo Posted January 27, 2007 Author Share Posted January 27, 2007 i didn't break it yet nipper, it broke itself actually what's interesting it that one of my buddies who has an OBXT, says his does the same thing, and a guy over on legacygt.com. the fluids look good (yes i still know how to check those :-p ) and the axles seem to be solid (can't move them laterally really) at first when i heard it i thought blown cv joint... but the boots look perfect, and i felt around em and it feels fine inside, for all i can tell. hmm.... i don't want to bring it to a dealer Link to comment Share on other sites More sharing options...
nipper Posted January 27, 2007 Share Posted January 27, 2007 You can always follow the other rule, turn up the stereo. The only other thing that can be done is the oil drained, geares dyed, and check for how the gears contact. Now let me ask you this. Is the clicking a 1:1 ratio, 2:1 ratio or a 4:1 ratio in refernce to wheel speed. nipper Link to comment Share on other sites More sharing options...
Andyjo Posted January 27, 2007 Author Share Posted January 27, 2007 Well.. since it only clicks when it's getting about 200+ft-lbs of torque to it i'm not exactly sure about the click:wheel spin ratio, i guess i could run beside it when someone's stomping on the gas.... i'm wondering if there's a bit of water in the diff.. frozen chunk or something. eh.. it's about time to go synthetic with is anyhow... Link to comment Share on other sites More sharing options...
