Scott F Posted May 22, 2007 Share Posted May 22, 2007 I get the slip joint idea, what I meant was could you elaborate on this statement. How can you use the outer joint as an inner? you could, but you'd need to put a slip joint in the middle, otherwise you'll hyper-extend them in a heartbeat. me and a few buddies are looking at doing something like this... Quote Link to comment Share on other sites More sharing options...
Scott F Posted May 22, 2007 Share Posted May 22, 2007 Please elaborate on this also. Where is the retaining bolt? there's an external 10mm torx bolt in the bottom of it. Quote Link to comment Share on other sites More sharing options...
Numbchux Posted May 22, 2007 Share Posted May 22, 2007 I get the slip joint idea, what I meant was could you elaborate on this statement. How can you use the outer joint as an inner? I don't know, that part wasn't my idea....I just know that if you replace the double offset joint on the inside with a second constant velocity joint, you'll need to add a slip joint. the whole point of having a double offset in there is so it'll telescope. the stub's retaining bolt is in the center of the stub shaft. Quote Link to comment Share on other sites More sharing options...
