MadMatt Posted January 31, 2007 Share Posted January 31, 2007 Need info on a transmission problem. I can get the car into 4-wheel drive, no problem. But it is extremely hard to get out of it, with a loud clunking sound coming from directly under the gearshift. What is it? Link to comment Share on other sites More sharing options...
idosubaru Posted January 31, 2007 Share Posted January 31, 2007 is this a PT4WD push button 4WD trans or something else? what do you mean it's hard to get out? are you moving, in snow, off road, sitting still.... Link to comment Share on other sites More sharing options...
Skip Posted January 31, 2007 Share Posted January 31, 2007 Sounds as if the center case is binding. This will result if your tires are not matched. Check all four for the same - size, brand, and pressure. This can also happen if you use the 4wd on surfaces that provide too much traction. To relieve the bind select reverse and back up for twenty feet or so. Hope this helps. Link to comment Share on other sites More sharing options...
Milemaker13 Posted January 31, 2007 Share Posted January 31, 2007 This happens in the loyale when in 4wd on pavement. Had mismatched tires to begin with, but still does it a little. 4WD off road or snow only:burnout: Link to comment Share on other sites More sharing options...
[HTi]Savage Posted January 31, 2007 Share Posted January 31, 2007 Make sure that ur using the clutch to shift in and out of 4 hi or 4 lo and back to 2wd. Like there saying make sure ur tires are all the same size. Link to comment Share on other sites More sharing options...
Virrdog Posted February 1, 2007 Share Posted February 1, 2007 Going in a straight line is important to getting the car out of 4wd also. Link to comment Share on other sites More sharing options...
Phizinza Posted February 1, 2007 Share Posted February 1, 2007 Sounds as if the center case is binding. This will result if your tires are not matched. Check all four for the same - size, brand, and pressure. +1, execpt I don't think the brand and pressure matter too much. Also if that all seems right we had the same problem with my brothers wagon when got it because it had a 3.7 ratio diff in the back and a 3.9 ratio in the front. As for checking your front diff ratio, I have no idea. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 1, 2007 Share Posted February 1, 2007 +1, execpt I don't think the brand and pressure matter too much. They do if you want it to work smoothly. If everything is setup correctly you should be able to go in and out of 4WD high at freeway speeds without using the clutch, and with no resistance of the lever. GD Link to comment Share on other sites More sharing options...
thatswhatshesaid Posted February 1, 2007 Share Posted February 1, 2007 Is it all the time? And what surfaces do you drive on? Link to comment Share on other sites More sharing options...
Milemaker13 Posted February 1, 2007 Share Posted February 1, 2007 +1, execpt I don't think the brand and pressure matter too much. Also if that all seems right we had the same problem with my brothers wagon when got it because it had a 3.7 ratio diff in the back and a 3.9 ratio in the front. As for checking your front diff ratio, I have no idea. Most of our cars should match front and back. This must have been a custom setup. I understand that in a straight mud runner, a faster front axle will help pull the front around where you want to go. But if it was locked on pavement, it would fail in short order. Did you guys swap it back or something? Link to comment Share on other sites More sharing options...
