casioqv Posted February 2, 2007 Share Posted February 2, 2007 Again, I'm not saying build a buggy. Just build the best darn offroad Subaru anyone has seen. If you're going to modify a subaru that much, where you have a divorced transfer case, custom built suspension, custom axles, and custom subframes front and rear there isn't anything "subaru" about it's offroad abilities. You could start with any passenger car, and get identical results. I would choose something with a strong lightweight unibody, a durable motor with lots of torque, and good rollover protection. Probably a Volvo 140 with a B20F engine, a mercedes W115 with an OM616 engine, or a 1.6l VW diesel 2 door wagon would be a better canidate than a Subaru. What's great about a subaru is that they are cheap, fuel efficient, handle like a car, and are reasonably good offroad. If you modify it like that, you lose all of those benefits except the offroad abilities. Link to comment Share on other sites More sharing options...
Hodaka Rider Posted February 2, 2007 Share Posted February 2, 2007 I would choose something with a strong lightweight unibody, Subaru= check a durable motor with lots of torque Subaru= check (depending on which engine, of course. BTW: motor=electric) and good rollover protection. Subaru= add a roll cage, just like everything else. What's great about a subaru is that they are cheap, fuel efficient, handle like a car, and are reasonably good offroad. If you modify it like that, you lose all of those benefits except the offroad abilities. Well, I guess the fact that it's a 4X4 to start with gives it an advantage over all of the other vehicles you mentioned. But I digress. I realize that the original intent of this thread was to find more power in the EA-82 SPFI and that I kinda sidetracked that. The obvious things have pretty much been said. You could always pull the heads and mill them a little, clean the ports/chambers a bit, etc. The exhaust can help, but keep it to 2" or 2 1/4". The big limiting factor on these engines is the port design and the long intake runners. Good for low RPM torque, not so good for HP. Link to comment Share on other sites More sharing options...
casioqv Posted February 2, 2007 Share Posted February 2, 2007 Subaru= check (depending on which engine, of course. BTW: motor=electric) If you're going to argue semantics... From the American Heritage Ductionary: Motor n. - A device that converts any form of energy into mechanical energy, especially an internal-combustion engine or an arrangement of coils and magnets that converts electric current into mechanical power. My point was that if you're locking the subaru transmission in 4WD and using a divorced transfer case, and entirely replacing the suspension/subframe you lose any advantage from the car already being 4WD, as you don't really use any of the factory 4WD parts. Sure a subaru is light, fuel efficient, and strong enough, but so are most passenger cars. I don't think it compares very well to those european cars I listed, but that's mostly a matter of opinion. Link to comment Share on other sites More sharing options...
tizzle Posted February 3, 2007 Share Posted February 3, 2007 The 1st thing I would upgrade with your car is, well not really an upgrade, but you should definitely replace all your coolant hoses. Link to comment Share on other sites More sharing options...
4WDFrenzy Posted February 3, 2007 Share Posted February 3, 2007 Well, my friend you are in luck. There is a whole slew of Subaru engines that will fit in the confines of your GL-10s engine bay. I'd probably either go with an EJ22 or my favorite, the EJ20G. Good luck! Patrick Link to comment Share on other sites More sharing options...
zyewdall Posted February 4, 2007 Share Posted February 4, 2007 I totaly dig the lowrange and can't believe how well it handles at speed offroad. For serious off-roading and rock crawling, you need solid axles, crawling gears, etc. That's not the strong point of subarus. But try rallying down some dirt road at 25mph and power sliding around the corners while hitting bumps and whatnot. You can do stuff with impunity in a subaru that would flip an off-roader. Each has it's niche. Subaru's also handle very well in the snow (except for the annoying tendancy to get high centered easily), as long as the wheels are touching the ground, it still moves. And they're pretty easy to pull out of a sideways skid (compared to my 4x4 truck -- I don't like driving that unless there's deep snow that needs bashing through). Link to comment Share on other sites More sharing options...
Prospeeder Posted February 4, 2007 Share Posted February 4, 2007 id love to know how you powerslide in a subaru, lol, the Parking brakes in the front! Link to comment Share on other sites More sharing options...
Uberoo Posted February 4, 2007 Share Posted February 4, 2007 scandinavian flick turn the wheel opposite corner then the correct way.really quickly.This unsettles the suspension.the back come around.then you control how long you want to drift by the throttle.steering corrections will probally have to be made.. Link to comment Share on other sites More sharing options...
daeron Posted February 4, 2007 Share Posted February 4, 2007 scandinavian flick turn the wheel opposite corner then the correct way.really quickly.This unsettles the suspension.the back come around.then you control how long you want to drift by the throttle.steering corrections will probally have to be made.. And here I was, thinking you were talking about the latest in Swedish Cinema... I hadn't heard that one either, though. Next time I feel the urge to spin the tail of the GL-10 around, I know how. Link to comment Share on other sites More sharing options...
Jub Nub Posted February 5, 2007 Share Posted February 5, 2007 i dont know about non-turbo power, but my mpfi turbo gl10 came alive with mandrel bent exhaust into the turbo, straight 2.5" out of the turbo, mandrel bent homemade intake tube, did a little dremel work on the intake and exhaust runners(could have done way better, ran out of time) got rid of power steering and air conditioning (less power to the pumps+more to the wheels) havent touched the boost yet. oh and i rebuilt the engine with the high compression carbed 'case. =great off idle torque and huge power all the way to 6500 which is as high as ivce spun it so far. Link to comment Share on other sites More sharing options...
kingbobdole Posted February 5, 2007 Share Posted February 5, 2007 scandinavian flick turn the wheel opposite corner then the correct way.really quickly.This unsettles the suspension.the back come around.then you control how long you want to drift by the throttle.steering corrections will probally have to be made.. Also known as a feint drift.... +1 on replacing the coolant hoses... first thing my wagon did right after I got it... started in on the hoses, one at a time:dead: Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted February 5, 2007 Share Posted February 5, 2007 I´ll Add the Vacuum Hoses too... the most are 3/16" and 1/8" ... Link to comment Share on other sites More sharing options...
NewDriverOlderRide Posted February 5, 2007 Share Posted February 5, 2007 Convert it to a Chevy 350! haha :headbang: Link to comment Share on other sites More sharing options...
Jub Nub Posted February 8, 2007 Share Posted February 8, 2007 Convert it to a Chevy 350! haha :headbang: or a caddy 500 Link to comment Share on other sites More sharing options...
Phizinza Posted February 9, 2007 Share Posted February 9, 2007 Why a V8 when you can have a flat four in there with 300hp+? Link to comment Share on other sites More sharing options...
daeron Posted February 9, 2007 Share Posted February 9, 2007 cue the photograph of the formula 1 flat 12 subaru engine... I dontt have it linked anywhere, but I seen it!!!! Link to comment Share on other sites More sharing options...
Durania Posted February 9, 2007 Share Posted February 9, 2007 Someone always has to throw something about a Chevy 350 in. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted February 9, 2007 Share Posted February 9, 2007 Hey!, there Goes the Subie Flat Twelve: Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted February 9, 2007 Share Posted February 9, 2007 ...Also, if anybody wants to see the Honduran Buggys´ Images I Got, I can post here some! Link to comment Share on other sites More sharing options...
Durania Posted February 9, 2007 Share Posted February 9, 2007 Whats the length on that flat 12? Link to comment Share on other sites More sharing options...
Phizinza Posted February 9, 2007 Share Posted February 9, 2007 Whats the length on that flat 12? Too long. Put it this way.. You'd have 2 or 4 cylinders sticking out beond your grill! Notice how this 60's(?) design engine looks alot like the DOHC EJ's? Only of cause much sexier... Why does it take so long for us to get cool stuff when the race cars get it right away! sorry, I got my wires crossed along with my eyes... Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted February 9, 2007 Share Posted February 9, 2007 The Subaru Flat Twelve is from around 1990 (So Basically maybe it is a "Evolution" of the EA82, as is the ER27) it was for the Subaru´s Formula 1 Racin´ car... but That´s another Story. In other old Thread, I suggested to install that Flat Twelve in the Back Side of a Loyale Wagon, as Rear Engined... Crazy but can be Done... Theorically... Link to comment Share on other sites More sharing options...
Phizinza Posted February 9, 2007 Share Posted February 9, 2007 The Subaru Flat Twelve is from around 1990 I must of got my wires crossed.. I thought it was old school formula 1... hmm Then again, that picture looks 80's... You could get a Ferrari flat twelve form a 512bb or a Testarossa, would do the same job. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted February 9, 2007 Share Posted February 9, 2007 ... You could get a Ferrari flat twelve form a 512bb or a Testarossa, would do the same job. Yes, but they simply Aren`t Subarus Montreal 90 Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted February 9, 2007 Share Posted February 9, 2007 Those are some Nice Ideas with Subarus: More Here: http://www.ultimatesubaru.org/forum/showthread.php?t=53434 Link to comment Share on other sites More sharing options...
