Bad Company Posted February 1, 2007 Share Posted February 1, 2007 Hello, I'm a new member here and I purchased(one day ago) my first Subaru. I'm not sure if it's too great of one but I like it. It's the 1988 Subaru Leone/Loyale/GL-10 4wd turbo with the ea82t series motor. I'd love this to be a rallye type car. I'm having problems finding out what I can do to this thing and where to find the parts. It has the 5 speed manual transmission, and if you'd like I can post pictures of it in like...1 - 2 days. I'd like to lower it and replace most of the suspension parts. We have these things called Rallye-Cross races here and you drive around in a huge parking lot going in and out of cones. I'd like to be one of the top contendors. I have until summer to make this bad-boy a worthy racer. I can't do turbo work, since the nearest place I can get it tuned is in minneapolis, minnesota. Please help me! I was wondering if I need to do anything special to my turbo/timing/intercooler if I put a blow off valve in there. Link to comment Share on other sites More sharing options...
SoobGoob Posted February 1, 2007 Share Posted February 1, 2007 not much of an aftermarket for these cars. actually not an aftermarket at all. try getting a spider intake and you probably have one of the fastest ea82's out there. if you really wanna get it going do a ej22 swap Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 1, 2007 Share Posted February 1, 2007 Bad Company said: Hello, I'm a new member here and I purchased(one day ago) my first Subaru. I'm not sure if it's too great of one but I like it. It's the 1988 Subaru Leone/Loyale/GL-10 4wd turbo with the ea82t series motor. I'd love this to be a rallye type car. You should have asked us before you went and bought it. Not a good choice for a lot of reasons. Bad Company said: I'm having problems finding out what I can do to this thing and where to find the parts. That's cause there really isn't any. Not in the sense that you mean. There's things you can do, yes, but without full-on engine management, you'll blow the engine if you try to take it much past 10% above stock, and you might blow it doing nothing at all - don't look at it cross-eyed - they don't like that. Bad Company said: It has the 5 speed manual transmission, and if you'd like I can post pictures of it in like...1 - 2 days. We've seen about a billion of them, but if you must..... the 5 speed is good, but the part time 4WD is not appropriate for pavement. Unless it's the Full-Time 4WD model? Those are good tranny's, but most models were not equipped unless it was an RX or a high end GL/GL-10. Bad Company said: I'd like to lower it and replace most of the suspension parts. Do a search for "5 lug swap". You'll need most of the front suspension from an XT6, and part of the rear to do it. The stock 4 lug has zero wheel/strut/spring options. It can get expensive because XT6's were rare, and are getting tough to find. Bad Company said: We have these things called Rallye-Cross races here and you drive around in a huge parking lot going in and out of cones. I'd like to be one of the top contendors. Haha. With the heavy shell, and whopping 115 HP, you're going to be one of the slowest cars out there. Bad Company said: I have until summer to make this bad-boy a worthy racer. I can't do turbo work, since the nearest place I can get it tuned is in minneapolis, minnesota. Please help me! I was wondering if I need to do anything special to my turbo/timing/intercooler if I put a blow off valve in there. Special? Yes - don't do it if you value your heads/headgaskets. BTW - you don't have an intercooler. These engines weren't built performance minded - many have come before you, and still others have spent years (I'm not kidding - we have a member that's spent years working on making a 200 HP EA82T even somewhat reliable, and he works for a subaru dealer). I can't even count the number of times he's "given up" on this engine. Without very expensive machine work, custom parts, and very, very sensitive engine management it's not going to happen. And when an EJ22 can be had for a few hundred, and tops the EA82 by 20 HP with no turbo at all..... well it's just not worth the time or effort. Anyway, your going to do what you like regardless what we say about it. But when you start looking for an early 90's turbo Legacy with the EJ22 turbo, and 5 speed AWD, you won't be able to say we didn't warn you. GD Link to comment Share on other sites More sharing options...
Skip Posted February 1, 2007 Share Posted February 1, 2007 Sorry mate, like GD says -- wrong choice Here is what I did and it's still a looser, it is all custom stuff. (87 GL turbo 5 speed 4wd) Please email me if you have any questions. Link to comment Share on other sites More sharing options...
Gloyale Posted February 1, 2007 Share Posted February 1, 2007 Check and see if it has a Limited Slip Differential. There is a sticker on the rear differential. It has the gear ratio. It will say LSD in big letters if it is a limited slip. If it is you've got at least that as a score. Is it FullTime AWD? or Dual range with Diff lock? or just single range push button? Link to comment Share on other sites More sharing options...
idosubaru Posted February 1, 2007 Share Posted February 1, 2007 Gloyale said: Check and see if it has a Limited Slip Differential. in general that is a nice score for bad weather or off road. but if it's a PT4WD, which i think it is, his rear diff isn't getting any power sent to it. on pavement he'll be in FWD. Link to comment Share on other sites More sharing options...
Indrid cold Posted February 2, 2007 Share Posted February 2, 2007 Bad Company said: Hello, I'm a new member here and I purchased(one day ago) my first Subaru. ///// .......................................... Hello Bad Company! *said all together.. Welcome to the board. Link to comment Share on other sites More sharing options...
Bad Company Posted February 2, 2007 Author Share Posted February 2, 2007 grossgary said: in general that is a nice score for bad weather or off road. but if it's a PT4WD, which i think it is, his rear diff isn't getting any power sent to it. on pavement he'll be in FWD. Yeah, it's full time 4wd. Yes I can turn off the differential. Another thing, it's got this funky fresh TRIP COMPUTER on the dash with a bunch of push buttons in front of the actual stick in the interior. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 2, 2007 Share Posted February 2, 2007 Bad Company said: Yeah, it's full time 4wd. Yes I can turn off the differential. That's a locking CENTER diff, which is completely different from the limited slip REAR diff. And you want to leave it unlocked for pavement. Still not as good as AWD (Legacy, etc) as it doesn't have the viscous coupling center diff - rather it's just open, or locked (for dirt, snow, etc). Better than 2WD, but you still lose all power to the ground if one wheel is up..... It's too bad Subaru didn't use Torsen diffs like some of the old Audi quatro's.... Bad Company said: Another thing, it's got this funky fresh TRIP COMPUTER on the dash with a bunch of push buttons in front of the actual stick in the interior. All GL-10's, and many turbo's etc. had that. It was also standard with digital dash cars IIRC. Usually they aren't too accurate unfortunately - especially on the turbo's as the older turbo's rarely get good mileage at this point - expect 20 mpg or less. It's common. If you drive like grandma, and tune/replace your injection sensors..... maybe 25. Keep your foot out of the turbo. The trip computers weren't able to check the fuel consumption - only the level of the tank, and based their calulations off that - pretty far from accurate usually 20 years later. Plus any modifications you make to the engine will invalidate it's pre-programed formulas. GD Link to comment Share on other sites More sharing options...
Bad Company Posted February 5, 2007 Author Share Posted February 5, 2007 Hey, my heater kind of isn't working. Any ideas what I can do? It pushes air thru the vents, it's just really cold air. Also, what's height control? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 5, 2007 Share Posted February 5, 2007 Bad Company said: Hey, my heater kind of isn't working. Any ideas what I can do? It pushes air thru the vents, it's just really cold air. Flush the heater core. If that doesn't fix it then you need a new core - about $60 and 6 hours of work to remove the dash and get at it. Bad Company said: Also, what's height control? Air bag inflatable suspension w/ride height control. They almost always fail, are difficult and very expensive to repair. Replace it with normal spring struts and coil-overs. GD Link to comment Share on other sites More sharing options...
Prospeeder Posted February 6, 2007 Share Posted February 6, 2007 where are these 60$ heatercores for EA82s i ask? The lowest i can find is over 100$ Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 6, 2007 Share Posted February 6, 2007 Rockauto has em for $85.... sorry $60 was the EA81 core. But still not over $100. Autozone has em for $71.99... even cheaper. Just got to do your homework...... GD Link to comment Share on other sites More sharing options...
