xoomer Posted February 3, 2007 Share Posted February 3, 2007 ok I got my wagon to run. but as soon as it starts it REVS up high and stays there, any Ideas? old hitachi carb? new lid gasket. Link to comment Share on other sites More sharing options...
misledxcracker Posted February 3, 2007 Share Posted February 3, 2007 when my '74 celica did that, it was a valve of some sort, stuck open... cant remember the name of it off hand sorry, ive rebuilt a carb but know NOTHING about them... used the picture diagram with the rebuild kit Link to comment Share on other sites More sharing options...
Frank B Posted February 3, 2007 Share Posted February 3, 2007 Check the linkage for smooth operation and make sure the fast idle cam isn't engaged. I guess you allready tried to adjust the idle with the idle screw? Also, the throttle cable can also do this if you installed or adjusted it while the engine was cold. After it heats up and the fast idle kicks down, the cable will be too tight. I would say to back off the idle screw all the way, back off the throttle cable all the way so there's a bunch of slack so nothing will be holding the throttle open. Then check for vacuum leaks. Link to comment Share on other sites More sharing options...
hatchsub Posted February 4, 2007 Share Posted February 4, 2007 did you hook all the vacuum lines up the right way? Im assuming you just put a carb on this car? When i put a carb on mine i had hooked up a line going to the secondary wrong so that the vacuum from the motor pulled it open imediately. Link to comment Share on other sites More sharing options...
xoomer Posted February 5, 2007 Author Share Posted February 5, 2007 Checked the lines. Got it to idle. but If I hit the gas It will not return to idle. Need new throttle cable and think that I might need to get a stronger return spring... Any suggestions. Link to comment Share on other sites More sharing options...
Frank B Posted February 5, 2007 Share Posted February 5, 2007 Is the throttle cable frayed? It may be the only problem. Disconnect it from the carb then work the throttle shaft. Does is return to the idle position? Look down into the carb bores and see if the throttle plate is jamming up on the sides of the bore, if you have excessive throttle shaft play. Theres a couple of throttle cables on Ebay, about the same price as a parts store, if any have them! Link to comment Share on other sites More sharing options...
xoomer Posted February 6, 2007 Author Share Posted February 6, 2007 ok... think the carbs ok.. I'm getting really jumpy timing.... and I can't get it anywere near 8 btdc... im usually about 10 or 15.. and this thing has no power any ideas?? off a tooth maybe?? Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted February 7, 2007 Share Posted February 7, 2007 Problems with Acceleration / No Power, seems to be the Secondary Stage of the Hitachi Carb. ... Maybe the Vacuum is improperly hooked to the Wrong point... but you can test if the Cable is Wrong, by Disconnectin` it and try to "Manually" accelerate... if it Returns to normal Idle, its the Cable. But if not, is a Carb Issue, I Suggest to try with the Secondary... But Even Better Solution is to Swap a Weber instead... I done that to my White Wagon, and it Never did perform better than with the Weber, and we got it since new in 1985... Good Luck! Link to comment Share on other sites More sharing options...
