crazy D Posted February 4, 2007 Share Posted February 4, 2007 ok ive always wanted to know whats the difference/ + side to NKG spark plugs. ....if swapping out my heads(ea81) is there anything else i need to replace while im at it(besides head gaskets)...thanks Link to comment Share on other sites More sharing options...
[HTi]Savage Posted February 4, 2007 Share Posted February 4, 2007 Yes u will need to replace intake gaskets and exhust gaskets. while ur at it u should get a reseal kit. rear main, front crank, ealve cover gaskets o rings. all is included in the reseal kit for about 70 bux. Link to comment Share on other sites More sharing options...
crazy D Posted February 4, 2007 Author Share Posted February 4, 2007 wow that sucks....stupid car being all expensive and stufff.....i dont have to remove the inake manifold to do it do i? Link to comment Share on other sites More sharing options...
zyewdall Posted February 5, 2007 Share Posted February 5, 2007 crazy D said: ...i dont have to remove the inake manifold to do it do i? To replace the heads? It's bolted to the heads, so yes. Unless I'm misunderstanding the question. Link to comment Share on other sites More sharing options...
[HTi]Savage Posted February 5, 2007 Share Posted February 5, 2007 Dude its deffenitly worth it to reseal the motor. If your oil pump is keeping good pressure and not leaking then dont mess with it. same with the water pump. Good luck. Soobs rock teh noobs. Lawrence. Link to comment Share on other sites More sharing options...
[HTi]Dain Posted February 5, 2007 Share Posted February 5, 2007 Quote Savage']Dude its deffenitly worth it to reseal the motor. If your oil pump is keeping good pressure and not leaking then dont mess with it. same with the water pump.Good luck. Lawrence. Hella yo! If it ain't broke, don't fix it, ya know. Buut if you have the motor out and all, may as well replace the rear-main, and what-not. Soobs rock teh noobs! Link to comment Share on other sites More sharing options...
crazy D Posted February 7, 2007 Author Share Posted February 7, 2007 ok well until the deads blow the hell up i dont give a S##T.....what about the NKG spark plugs? Link to comment Share on other sites More sharing options...
Phizinza Posted February 7, 2007 Share Posted February 7, 2007 I have no clue why people like the NGK's over others.. My car came with Denso's and they lasted ages, I finaly replaced them because I thought they were causing a miss fire but the new NGK's were the exact same... I've seen old looking bosch plugs in a EA81 at the JY, nothing wrong with them at all.. The way I see it, a cheap spark plug is a cheap spark plug. Link to comment Share on other sites More sharing options...
jeffast Posted February 7, 2007 Share Posted February 7, 2007 don't use bosh plugs, i'v seen no differance between, ngk autolight and delco but i'll never use bosch plugs again Link to comment Share on other sites More sharing options...
