sickofitall1113 Posted November 20, 2003 Share Posted November 20, 2003 how would i connect something so it would turn off when the car does, such as a volt meter, in otherwords. where is the ignition switch wire so i can tap into it, please answer, thanks.,..gerry Link to comment Share on other sites More sharing options...
Legacy777 Posted November 20, 2003 Share Posted November 20, 2003 there are a couple places you can tap into. You don't need to tap directly into the ignition key source, just a lead that is switched on/off with the ignition. I can't give you a specific spot. You'll just need to prob around with a test light or multi-meter. Other option is to tie the voltmeter into an accessory on/off lead, such as a lead that the radio connects to. Link to comment Share on other sites More sharing options...
frag Posted November 20, 2003 Share Posted November 20, 2003 The cigarette lighter hot wire is probably the easiest to tap. Link to comment Share on other sites More sharing options...
